Attachment points
   / Attachment points #1
Beaux Duke
S.E. Louisiana
Kubota L48
I just got through searching the forum for pictures of rigs to see where/how everyone is attaching their chains to the tractor when on the trailer.
I couldn't find any clear close up shots of the front and most of the rear seemed to be going to the center of the 3 point hitch.
You can see by the number of posts that I'm a rank amateur so if you have any close up shots of how you secured the chain to the front of the tractor I'd like to see'em. I'd like to appear somewhat knowledgeable when I pick up my tractor this Tuesday. I guess I could just stand back and let the dealers crew do all the work but I'd like to know if it's being done properly.
I've already bought the chain and ratchet binders. I just need some ideas on how to route the chain.
   / Attachment points #2
I use one in front hooked to side trailer wrap around center Axel to other side
hooked and bind ed.Same on rear axle.Lot of guys like four chains one on each corner.Framer
   / Attachment points
So you use one chain, looped around the axle as close to the center as you can get it then use one binder on the other side? Same technique for the rear?
   / Attachment points #4
2 of my current tractors all have pins for the front attach and my other one I loop over the front axle to do the front. On the rear I either use the rear hitch on the drawbar or run thru the space where you can adjust the drawbar from side to side. I use one chain and one binder on each end of the tractor. Some states require(and some people prefer) 1 chain and binder at each corner. I have seen quite a few tractors and even full sized backhoes hauled with one chain and 1 binder using the front of the trailer as a stop and pulling the equipment forward with the chain/binder. I would not recommend this practice at all, there is no safety margin at all if a chain comes loose.
I also like to set up the binders where I can see them out of the driver's side mirror. That makes them much easier to monitor. I also check the chains and binders a short distance from the house. If nothing has come loose on my road I'm good for the trip.
   / Attachment points #5
I consider myself lucky having very solid and easily accessible connection points on my tractor, especially being new to trailering myself. Seen some guys where they had to have some kind of D-rings welded on to the frames to facilitate binding them on a trailer, which would be a worthwhile investment if you had to do it.
Here's how I did mine.
JB.
   / Attachment points
Thanks guys.
I really like your set up JB4310. The pictures really help. 1000 words X's 3!!
I've bought the Grade 70 chain. It came in 20 foot lengths. From what I see you are using about 10 feet per corner, maybe less. Did you cut yours or did you just buy the length you need. I already have two 20 foot lengths so I'm thinking of cutting the middle link and get more Grade 70 hooks.
I bought the chains and ratchet binders from Harbor Freight but I'm heading to TSC this morning to see if they have American made chain and binders. Another story in the news yesterday about rocket fuel in baby food from China.:(
What's that old saying? "You get what you pay for"
It's kinda funny, I'm kinda reluctant to use chain because I don't want to scratch my tractor :eek: but then I plan to use it clearing a couple acres.
   / Attachment points #7
   / Attachment points #8
bduke- you should study jb4310 pictures closely. If you can take a moment and look at the chains going through the stake pocket and then back up and the hooks is simply resting there going down. This is the federal DOT preferred way of chain attachment on the trailer. The reason behind it as i understand it is that if the chain ever gets loose, the chain won't be flapping all over the place and its still secured on the trailer. I just wanted to point this out since this is how the pros do it too.;)
   / Attachment points #9
I'm brand new to equipment trailering so I was reluctant at first to use the stake pockets to attach chain to, thought they were for wood stakes, but everyone assured me that's the way to do it.
JB.
   / Attachment points
Yeah, I noticed how the chain was routed through the stake pocket right away. Looked to be a good idea right off the bat. That's the sort of info I need.
I have a 36 foot 5th wheel RV that I pull so I'm used to having something big and heavy behind me. I just want to make sure the load is locked down securely.
The tandem axle car hauler I already had is insufficient for the tractor (almost 8k lbs) so I'll be borrowing my SIL's trailer for a while to haul it back and forth from my current home to the site I'll be clearing. His is rated for 10,400 lbs gvwr so I'm thinking I might need to step up to something with more capacity. After I see how his does I can decide if I should go with a 12k or 14k.
The trip to TSC was a let down. Chain was exactly like the Harbor Freight chain but priced higher. Had the "China" marking on it.
I checked out the link to AW Direct. Looks like their prices are reasonable. If I can't find some locally, I'll probably order some from them.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
Informational Lot - Shipping (A56438)
Informational Lot...
48ft all aluminum feather light wedge trailer (A56438)
48ft all aluminum...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
