Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Gold Member
    Join Date
    Jul 2007
    Posts
    446
    Pennsylvania
    Bobcat
    Default Pics of equipment tied down to trailer
    I was wondering if some people could post pics of their equipment properly tied down to their trailers. I have seen so many ways of it being done and would like to see the correct way if possible.
    I have a Bobcat CT440 with backhoe and just bought a new 20ft 12k trailer, so im all about safety, so any pics would be great.
    Thanks
  2. #2
    Join Date
    Sep 2006
    Posts
    187
    ohio
    kabota
    Default Re: Pics of equipment tied down to trailer
    here is my toy
    Attached Thumbnails Attached Thumbnails Pics of equipment tied down to trailer-picture-010-jpg
  3. #3
    Gold Member
    Join Date
    Jul 2007
    Posts
    446
    Pennsylvania
    Bobcat
    Nice setup there, could you give me the specs of yr trailer and equipment. How many chains do u use with yr setup?
  4. #4
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    This has been covered 100's of times here, do a search. In a nut shell you need 4 chains minimum. Most like 10' pieces of 5/16" grade 73 chain and 4 load binders. You can get good 5/16" grade 73 at Lowes in 20' length and have them cut it in half then get more hooks there to install.
    The way I like to do it is put the chains in a X fashoin. That is hook a chain to the right rear axle then to the left side of the trailer then a binder to snug it up and so on.
    As for the loader put a 2" ratchet strap or heavier over it securing it to the trailer along with any other implement to the trailers deck.
    Chris
  5. #5
    Gold Member
    Join Date
    Jul 2007
    Posts
    446
    Pennsylvania
    Bobcat
    Chris thanks for the info. I have done alot of reading and it seems like people do all sorts of things when tieing down, 1 chain, 2 chains, some use straps, load forward, load backward, so I just wanted to know the correct way. I like yr ideas of crossing chains and strapin implements to deck.
    Thanks
  6. #6
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Going on the trailer forward or backward is a matter of load balance. My tractor and trailer setup seem to work better backed on but it varies from setup to setup. Just experment to get the load leveled with about 10% or so on the tongue then strap it down good.
    I like 4 separate tie downs. That way lets say one back on comes loose you still have one back one preventing it from coming forward and possibly into the back of your truck or SUV.
    Chris
  7. #7
    Gold Member
    Join Date
    Jul 2007
    Posts
    446
    Pennsylvania
    Bobcat
    Sounds good Chris, with good advice and alot of common sense I should be fine. Saftey first!!!
    Thanks
  8. #8
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Quote Originally Posted by tinman955 View Post
    Should have a chain on each corner.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  9. #9
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    It's tough to see in the picture but I use 4 chains and binders, one at each corner and criss-crossed to the corners of the trailer. I also put one 2" ratchet strap over the loader and one over the backhoe.
    click thumbnail for larger image
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  10. #10
    Super Member Highbeam's Avatar
    Join Date
    Feb 2005
    Posts
    5,039
    South Puget Sound, WA
    Kioti CK30HST
    I have the Kioti version of your machine. I use 4 seperate chains and 4 seperate ratchet binders. I chose to use 3/8" grade 43 chain.
    The rear end of your tractor has a serious drop hitch and you will thread the chain through this hitch (not the drawbar). From the hitch you go to the trailer tie downs. In front you will put your chain through the front of the frame right behind the grille guard and in front of the sheet metal body. The frame is about 4" tall there.
    Your tractor is heavy. Plan for 4500 lbs with a rear implement and more with a backhoe. My 10k rated trailer weighs 2500# empty so it works out. A 7000 lb car hauler trailer will be near the max.
    I personally don't strap down the loader. It won't fall off. The brush mower gets pinched under the rear chains and the Box blade just rides there also. They won't fall off the tractor since there are some stout pins holding them on the machine. I never quite understood why people and the rules say they should be strapped down. I don't strap down firewood in the bed eof my truck either, or the tractor seat.
    Attached Thumbnails Attached Thumbnails Pics of equipment tied down to trailer-smalltruck-jpg
    Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
