HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-01-2009, 07:29 PM   #1 (permalink)
hunterridgefarm's Avatar
Default 2002 F250 Diesel Problem...Hurry!!
Guys I need some help here. 50k miles on my diesel with no problems until now.
Problem is the instrument panel and accelerator does not work. Lights, mirrows, signal, and everything works. Press the accelerator and nothing, fuel, oil, temp, gauges don't work. I was able to idle the truck to shade in order to check fuses. I cannot find a bad fuse. Thinking maybe a relay???
Anybody know what it could be???
It worked great early today. I was going to move a trailer load of mulch, backed up to the trailer, hooked it up and when I started the truck, no acceleration and no gauges working...???
I have about 12 hours to fix it or I'll have to get it towed in.
Thanks in advance for any help!
__________________
But Dear...No man is smart enough to remember everything he knows!!
hunterridgefarm is offline   Reply With Quote
Old 07-01-2009, 08:21 PM   #2 (permalink)
Elite Member
wushaw's Avatar
Default Re: 2002 F250 Diesel Problem...Hurry!!
Miniuse # 41 10amp controls dash and throttle.
I did a little searching to find this and it was someone with your same year and motor.
__________________
Kubota L2800HST, Mitsubishi 372, bh75, 45" Agric tiller, 5' home made disk, 42" Bush hog, PHD, 66" Cammond BB.
wushaw is offline   Reply With Quote
Old 07-01-2009, 11:00 PM   #3 (permalink)
I'll try replacing that one and see if it works. I did pull # 41 and could not visually tell anything was wrong with it. Wish I had some extra fuses.
I'll go get a couple early tomorrow.
THANKS!!
__________________
Old 07-02-2009, 09:51 AM   #4 (permalink)
Check this morning...#41 is not it
__________________
Old 07-02-2009, 10:15 AM   #5 (permalink)
Gold Member
Do you have a "chip" installed?
If so take it out and see what happens. I have a buddy with a 99 F-250 that did werid things with a chip installed. When he connected a trailer and disengaged overdrive all kinds of crazy things happened. We spent hours in wiring manuals trying to figure it out. All problems solved when chip removed.
The overdrive button on end of gear selector is a known problem area for shorting out.
Also try going to " the dieselstop" web site lots of good folks there.
Gather this info before searching the "dieselstop".
does door dinger sound with door open and key in ignition?
turning ignition to on , not trying to start, do instr lights test?
turning ignition to on. not trying to start, does "wait to start" light come on?
__________________
Mark
New Holland TC-45D * Kubota M5400 * Bobcat T-190
GATC35 is offline   Reply With Quote
Old 07-02-2009, 10:50 AM   #6 (permalink)
Gold Member
Could be your CPS (cam position sensor) Ford has a recall on these, they will replace free.
also read this one
Truck runs but no accelerator - Diesel Forum - The Diesel Stop.com
__________________
Mark
Old 07-02-2009, 11:23 AM   #7 (permalink)
Elite Member
Diamondpilot's Avatar
The cam sensor is a problem area on the 7.3 but does not explain the dash lights. I have a feeling it has something to do with the trailer he hooked up. Wonder if the wiring did something funky to fry things?
Chris
Diamondpilot is offline   Reply With Quote
Old 07-02-2009, 02:02 PM   #8 (permalink)
Elite Member
Highbeam's Avatar
I have experience with faulty CPSs and the issue is not the CPS. The new ford CPS released through the recall is great though.
__________________
Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way.
Highbeam is offline   Reply With Quote
Old 07-02-2009, 04:50 PM   #9 (permalink)
Gold Member
Ryan03's Avatar
If the truck is chipped, or has been chipped in the past, check the pins where the chip is or was plugged into the ecm, as they can become slighltly corroded, or loose and lose conection over time.
A normal sign of this is a 7.3 that shuts off, and opon attempting a restart, will not illuminate the glow plug lamp. I have never seen your exact problem, but if I was working on it in my shop, the ecm contacts would be the second place I would look, the first being fuse 41 which has already been mentioned.
Good luck
Ryan
Ryan03 is offline   Reply With Quote
Old 07-03-2009, 04:47 PM   #10 (permalink)
Thanks for the replys guys.
I had to have it towed in. Turns out there was a wire in the steering cloumn that had rub the insulation off and it shorted out the fuse. Fixed the wire, replace the fuse and WERE GOOD!!!!!
Thanks again,
David
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.19075 seconds with 8 queries
