I'm hoping some of you with a lot more experience than I can help.... I've gone through the owner's manual carefully, and can find nothing on the surge brakes for my T@B camper, other than that "it has them."
As near as I can figure, after removing coupler's plastic cover and crawling around under it, there is no electric or hydraulic connection to the brakes at the wheels, only a cable, just like the parking brake on a car. There is also no electrical connection anywhere to the parking brake or the coupler. (Don't know why they used a 7-pin round-- one size fits all?)
The knobs on the front- the topmost red knob is the wheel jack --which turns "backward" by the way, clockwise for lower!-- the red-handled tall/long lever is the parking brake, and the smaller red-handled piece on the left side of the wheel jack is a lock for the wheel jack's shaft; wheel and shaft are lifted up into the frame for storage after connecing to tow vehicle.
The red cable is a breakaway cable, and is hooked into the base of the parking brake lever, so it actuates the very same steel rod the parking brake does.
There is nothing going back toward the wheels except the steel rod, which ties in to a "Y" cable on the rear axle.
I haven't yet taken the wheels off, but I will! I'm just wondering about the system: it appears to be strictly mechanical, and must have some provision to allow for backing up, but I don't yet know what it is.
The system is a German design, and may not be regularly seen in this country...? Any ideas and/or experience with these?
