Results 1 to 4 of 4
  1. #1
    Join Date
    Aug 2008
    Posts
    135
    Default Flatbed with Torque Tube
    I'm looking for a gooseneck tandem dual flatbed. I've come across a Becker low profile and it has what they call a torque tube down the center. Does anyone have experience as to how useful or effective a torque tube is? It's supposed to reduce twisting of the frame but I didn't realize that was a problem on regular frames. Maybe it's something to make a lighter weight frame work like a heavier frame without it. Does anyone have any knowledge of the quality of the Becker trailers? Thanks.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #2
    Elite Member
    Join Date
    Oct 2003
    Posts
    2,799
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    Default Re: Flatbed with Torque Tube
    We used to put two 100x100x4mm torque tubes between the spring hangers on air suspended trailers. The most torsionally rigid trailer we've built, was indeed a electgro hydraulically steered two axle lowbed, with a central tube chassis of 400x200x8mm tube. In Europe all heavy equipment trailers are built from a welded box section.
    Free scrap is a good investment !!!
    “The worst enemy of life, freedom and the common decencies is total anarchy; their second worst enemy is total efficiency” · Aldous Huxley
    __________________
    1967 Zetor 3011, restoration in progress: Technically new, just needs the cosmetics..
    1973 Zetor 5718, home made loader
    1998 Volvo S70 TDI
    2007 Volvo 440 1.9 TD based dirt buggy, needs time !
  4. #3
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,719
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Quote Originally Posted by Believer View Post
    Interesting.
    Don't know about torque tubeson GNs, but the 1951 Minneapolis Moline BF tractor that I'm presently restoring has a torque tube setup between the clutch housing and the transmission case.
    This tractor is laid out engine-clutch-drive shaft-tranny-rear end. The drive shaft goes through the torque tube.
    The torque tube is a stiffener that keeps the two main support rails (C-channel) of the tractor from twisting due to engine torque. I suspect that the torque tube(s) on that GN you're looking at have a similar function (preventing the frame from twisting).
  5. #4
    Gold Member
    Join Date
    Jun 2006
    Posts
    332
    Texas
    Massey Ferguson 2135
    I don't own a trailer with a torque tube, but they work like a sway bar on a car by reducing the roll of the trailer in turns. Good to have if you haul tall heavy loads.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
