HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-17-2009, 09:53 PM   #1 (permalink)
Elite Member
flusher's Avatar
Default Tongue weight scale
I'm thinking about getting one of these
Sherline Trailer Tongue Weight Scales
for use with the 10K GN trailer that I plan to buy in a few months.
Anyone have any experience with one of these scales?
Are there better or cheaper alternatives?
flusher is offline   Reply With Quote
Old 10-17-2009, 10:56 PM   #2 (permalink)
ToadHill's Avatar
Default Re: Tongue weight scale
It depends how much tongue weight you want. I've used a bathroom scale set on blocks at the same hight as the hitch. Scale I used will go up to 350lbs and I've not needed any more tongue weight than that.
__________________
I can't control my day but I can control my attitude.
ToadHill is offline   Reply With Quote
Old 10-17-2009, 11:08 PM   #3 (permalink)
Elite Member
flusher's Avatar
Quote:
As I understand the setup used for GN trailers, pin weigh should be 15-25% of the towed load. So with a fully loaded 10K GN, the pin weight could be as high as 2500 lb. Can't handle that with my bathroom scale.
Old 10-17-2009, 11:19 PM   #4 (permalink)
Willl's Avatar
I've used this method before.
__________________
I refuse to participate in any type of recession.
Timothy 2:11-12
My Photobucket
Willl is offline   Reply With Quote
Old 10-17-2009, 11:23 PM   #5 (permalink)
I usually guess at it,after years of towing,you can get a pretty good idea of where your at,and where you need to be at.I have taken my camper to the cert scales just because im travelling far,and i wanted to make sure my axles weights were all ok.I have the biggest issues with my dump trailer,I end up with 1500-2000lbs tongue weight pretty easily,and i dont want to hook up the W/D bars for the 3 mile trip home.My 3/4 t HD trucks like 900-1200lbs tongue weight on all my larger trailers(33ft sunnybrook,14K dump,and 9900 flatbed).My 7k enclosed you can run as light as 700 and be ok,but it handles better at 8-900.
The tow vehicle will tell you if your too tongue light or heavy,either way will result in poor handling.IMO tongue light is very dangerous,as the tail wags the dog easily here.I always run a little tongue heavy if im not sure,and readjust the load back after a short drive if its too far forward.
__________________
Cat 246 SS,Homemade 35T log splitter,
Raw Dodge is offline   Reply With Quote
Old 10-18-2009, 12:52 AM   #6 (permalink)
JDGREEN4ME's Avatar
I have that same model scale and it works fine...
JDGREEN4ME is offline   Reply With Quote
Old 10-18-2009, 12:37 PM   #7 (permalink)
streamin's Avatar
I bought that same scale 2+ years ago and have been very happy with it.When I move the tractor just a little you can see the difference easily. I try to run between 900-1200lbs.
I would highly recommend it.
streamin is offline   Reply With Quote
Old 10-18-2009, 02:45 PM   #8 (permalink)
Elite Member
flusher's Avatar
Quote:
Good suggestion. Thanks.
Old 10-21-2009, 10:08 AM   #9 (permalink)
Quote:
Originally Posted by Raw Dodge View Post
....My 7k enclosed you can run as light as 700 and be ok,but it handles better at 8-900.
With the WD bars on our 7K trailer 750 to 1000 works fine. I tend to run nose heavy also. With the coupler locked and nose heavy, you're not going to come off the ball. Tail heavy and you could. And as you said, tail heavy can get squirrelly.
FlaDon is offline   Reply With Quote
Old 10-24-2009, 01:49 AM   #10 (permalink)
Interesting device the little tongue scale. I have successfully used the bath scale and the board for weights exceeding the scales limits.
GE222 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.26508 seconds with 8 queries
