Refurbishing the Trailer
   / Refurbishing the Trailer #1
Egon
Epic Contributor
Nova Scotia, Canada
My good old trailer had served me well but was getting aged. Rust was prevalent, the floor boars were rotting out at the ends, a axle was bent and the ugly box was deteriorating.:(
So, on to getting it back in shape. First the ugly overweight box was pulled off. Then the floorboards followed. These were a pain as the self tapping screws would not come out. Had to break them off with the floor boards or pry bar.
Now we have the bare frame and the real work begins. Probably 70 or so hours with a needle scaler and air hammer removing rust. It may have gone faster with a bigger air compressor. Angle grinder and wire brush for a few more hours. Wore out one Makita angle grinder.:( Caught the wiring and wrapped it up with the grinder so much of it had to be rewired. [connections all soldered and heat shrink wrapped] Still picking wire out of myself and clothing.:(
Took it to a shop and had new fenders, a new hitch and ramp holders welded on.:D
Then the finishing part. A coat of Dairy product line cleaner, wire brush it off and do some more scaling. Another coat and wire brush followed with a coat that stayed on. Two coats of Rustoleum Paint, three in some places and then sprayed the under parts with an acrylic driveway sealer. the sealer went on easy, looked good for several days and the flacked off easy. So, back to the messy roofing tar and Varsol mix and two coats sprayed on. Four coats on the fender bottoms.
All this rust removal and painting took place in +35C weather out in the direct sun. In an eight hour day I'd lose about five to eight pounds.
Next cut the pressure treated 2x8 spruce floor boards to fit, then slathered more roofing tar on the cross channels, ends and the ends of the boards, drilled holes and bolted down the floor. Added double row of boards where the tires run.
All done and passed inspection. Now to build a tool box and side add side boards.:D:D
Having problems transfering pictures:confused:
   / Refurbishing the Trailer #3
Nice work.
Chris
   / Refurbishing the Trailer #4
hmm roofing tar ? yours is the first I heard of tar on trailers. For all the salt you drive in ?
   / Refurbishing the Trailer #5
Wow! Big difference from start to finish.
What do you figure the re-build cost you in materials?
   / Refurbishing the Trailer #6
Very nice transformation.
I really like the jacks at the end. They must make it nice when loading and unloading.
What type of ramps do you have and how do they attach?
Eddie
Thanks for all the replies.:D
There is a lot of salt used here in the winter. The trailer had a lot of rust on it and the roofing tar is an attempt to stop the rusting. It's also quite inexpensive.:D The truck undersides have been treated the same way.
The cost is considerable considering the axles were replaced. Guess would be almost 3K.:D
Eddie, the ramps are about 5 feet and slide in under the back.:D
I'd post a picture but am having some yes/no problems.:mad:
   / Refurbishing the Trailer #8
Nice job Egon! Can you tell me a bit about the "Dairy line cleaner"? Not something I have heard of before.
MarkV
RUST PRIMER
This read is pretty long but toward the end they get into phosphoric acid and how it reacts with rust. The Dairy line cleaner I used contains Phosphoric acid.
Note the black stains and streaks in one picture. This is after painting with the Dairy cleaner product of which there are many different brands.
Found out about this from "Thingy":D:D
It's also a whole lot cheaper than naval jelly and goes on much easier.:D
I did the same to the undersides of the truck.:D
I can't claim that this procedure is proper or will work as my knowledge is limited!:eek:
   / Refurbishing the Trailer #10
Found out from Thingy............and it is a rust remover........then it....well....removes rust.:D:D:D
MarkV
2023 JOHN DEERE 8R370 LOT NUMBER 201 (A53084)
2023 JOHN DEERE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
2017 VOLVO EC250EL EXCAVATOR (A51246)
2017 VOLVO EC250EL...
RV Hitch (A50121)
RV Hitch (A50121)
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
