Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Platinum Member lakngulf's Avatar
    Join Date
    Oct 2009
    Posts
    572
    Lake Martin Alabama
    Kioti CK30
    Default Too much slope
    Even a little slope (covered with pine straw) is too much slope for trailering. There are few (read no) actual level spots at my house. I have one area that has worked great for loading and unloading tractor. Last night I stopped the truck and trailer with tractor in a slightly different spot, set the emergency brake and began the process of unloading tractor.
    I started the tractor, un chained the tie downs, placed the ramps and began to back off. As the tractor hit the spot where it "lifts" the rear of the truck a bit, I noticed that the ground was moving faster than I was backing up. The truck and trailer were moving foward down the pine straw slope. In front of the truck was my wife's car, and beyond that was the kitchen door. Do I drive forward with the tractor to get the truck back firmly on the ground, or do I continue backward? There really was no time to do anything.
    The truck was turned slightly left at parking (that might have been part of the problem as well) but as it was pushed forward it turned more sharply left to miss the car. The trailer, before it could follow the truck left, found a tree with the right part of the frame, and everything stopped abruptly. I breathed a sigh of relief, and issued a reprimand to myself. I think my only damages are my ego, my confidence in trailering and a dent in the trailer frame.
    I think I will put a block in front of trailer wheels when loading and unloading from now on.
    Kioti CK30, KL130 FEL with Markham Toothbar, Land Pride 6' Mower, Atlas 6' BB,KK Tiller, KK Bushhog, Chisel Plow, Howse 66" Disc, 7' Spike Tooth, Hollow 300 Seeder
  2. #2
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,060
    Ontario, NY
    Kubota BX24
    Default Re: Too much slope
    wow! it couldnt gotten real bad fast. good thing you are ok. But one question, don't you have jacks in the back of the trailer to prevent this happening? chocking will help but still have the spot of trailer to lift truck. Even if you don't have a permanant jack, anything will work. be it a floor jack, bottle jack, scissor jack from truck, old fashioned farm jack, even jack stands if you use the tongue jack to lift from till back is touching jack stand firmly.
    I am glad you are safe and nothing damaged but ego. Its always easier to have a bruised ego then actual damage on car, house, yelling wife .
  3. #3
    teg
    teg is offline
    Elite Member
    Join Date
    Jul 2005
    Posts
    3,943
    dsfasdf
    sdfadfa
    I block the tires with 6"x6" wood blocks even on flat ground... Another thing I did was to create a Flat spot to park and unload the trailer. Changing the sloping ground to usable flat area for extra parking...
    TractorByNet.com, WAS next best thing to seat time - not any more.
  4. #4
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    This happens all too often. You were lucky you were not hurt. One of your members got a broken arm, bent trailer, and a bent truck with the same chain of events.
    Here are a few suggestions. Put the truck in 4x4 if available. It will allow the tranny to lock the front axle also. Block the tires of the trailer, this is a no brianer. Pull the brake away cord on the trailer to set its brakes. Put jack stands under the rear of the trailer to keep it from lifting the back of the truck.
    Chris
  5. #5
    Platinum Member Steve C's Avatar
    Join Date
    Jul 2009
    Posts
    637
    North Central Michigan
    Farm Pro 2425
    Quote Originally Posted by lakngulf View Post
    Wow that sounds like a wild ride! I would have to change my shorts after a ride like that one.
    I am glad that you got a free pass, it could have been ugly! I would block the front wheels of the truck along with the trailer wheels and then I would block the back of the trailer so it can't drop and lift the truck. That way a single point failure of the blocking won't result in a replayof your wild ride. I think the key is to keep the rear wheels of the truck on the ground and fully weighted.
    Craftsman GT 18
    Craftsman GT 18.5
    Craftsman GT 22
    Swisher 2660
    Farmpro 2425
  6. #6
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,617
    Nova Scotia, Canada
    Picture showing tractor being loaded with rear jacks on trailer.
    Attached Thumbnails Attached Thumbnails Too much slope-pb190013_edited-1.jpg
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  7. #7
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    11,418
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC 2042
    Glade the out come was positive on...whew.
    Egon attach to me best way to go..also chalk tires.
  8. #8
    careyo63
    Guest
    Egon looking at your trailering pic. sure does remind me of how much I like my dove tail. Don't get me wrong I have to watch not to drag it. I'm pretty flat here in GA. and hasn't been a issue yet. I just throw a couple of wood blocks under the tail when I load or unload just to be safe. Plus it also inables me to leave my attachments on.
    Attached Thumbnails Attached Thumbnails Too much slope-trailer-pics.-001.jpg
  9. #9
    Join Date
    Aug 2001
    Posts
    16,617
    Nova Scotia, Canada
    The dove tails would be nice. Unfortunately my trailer had to serve for other purposes not compatible with a dove tail.
    Egon
    Livin in a
  10. #10
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    I am like you Egon. I have had a DT trailer and it was my last. I much prefer the flat deck. Others like the DT so I guess that is why they make both types for each individual buyer.
    Chris
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
