Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Join Date
    Nov 2008
    Posts
    550
    Central Illinois
    Many JD
    Default Re: Tractor and Gooseneck Hitch
    I made this one for my camper and flat bed. The camper is all it wants and I have never moved the flat bed with a load. I don't know how what kind of tractor you have but I think I would want a catagory III tractor before taking that much weight off road.
    Dan
    Attached Thumbnails Attached Thumbnails Tractor and Gooseneck Hitch-img_0279-jpg
  2. #12
    Bronze Member derekuk101's Avatar
    Join Date
    Mar 2008
    Posts
    60
    KY
    M8540, M4900, Ford 5610, Ford 3600
    thanks for all the replys. I will probably just use my old hay wagon. Not really wanting to damage the tractor, trailer, or operator anytime soon.
  3. #13
    Elite Member Duffster's Avatar
    Join Date
    Mar 2009
    Posts
    4,372
    Wisconsin
    Quote Originally Posted by derekuk101 View Post
    Your not going to damage anything,
    We pull our gooseneck in the feild all the time. You just have to use your head, no different then pulling wagons or implements.
    "If everyone is thinking alike, someone isn't thinking." George Patton
  4. #14
    Gold Member
    Join Date
    Jun 2006
    Posts
    332
    Texas
    Massey Ferguson 2135
    I don't have a picture of the trailer hooked up to the tractor, but here is a 3 point hay spike with a gooseneck ball on it I built several years ago. I use it to move my hay from the fields with a 20 foot gooseneck trailer (not the 32 foot trailer shown).
  5. #15
    Super Member Dargo's Avatar
    Join Date
    Mar 2004
    Posts
    5,980
    S. IN
    Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
    Quote Originally Posted by MikePA View Post
    Not sure who makes the TSC version but check out Summit Fab (click here). They have a heavy duty GN version for Cat 1, 2 and 3 tractors that come with a 2 5/16" ball, Model# FPHS-SDEG, $399 + $55 shipping.
    Man, their heavier (and more expensive model) looks like what I welded up in my shop a few years ago. I made the obvious mistake of selling a couple on eBay like I did my regular hitch and now I see almost identical copies being sold by companies. It seems to be based on my first version that didn't include the safety chains that keep the 3 pt. hitch from moving up when you're stopping though. I'm not going to even post a picture of that final version for obvious reasons. Here's a picture from about 5 or 6 years ago of my first prototype. I've used this very hitch (still unpainted ) on a 100 hp tractor to move around a loaded GN trailer that weighed about 15,000 pounds. The only difference is that I'd updated this hitch to include my safety chains to keep the hitch from moving upwards if you stop fast or go down a steep hill.
    Attached Images Attached Images
    1982 18" Murray push mower (B&S industrial 8 hp engine!) custom deck, new blade - became unbalanced when one side old blade broke off!
    HF moving dolly - high torque! Dogbone multi-wrench too..wait, it split on first use.
    My trash man is the greatest. No matter how bad the economy gets and how bad stocks drop or how bad home values drop, his business is always picking up.
  6. #16
    Platinum Member firefighter9208's Avatar
    Join Date
    Dec 2006
    Posts
    826
    Springville, Alabama
    2004 Kubota M4800
    I moved a 25'+5 gooseneck with 200 square bales on it behind my M4800 kubota (48 hp). I did have to put a round bale on the FIL hay spike to keep the front tires on the ground. The 3pt didn't have a problem picking it up though.
    Chris
    2004 Kubota M4800 with Bushhog M346 Loader with 6' Heavy Duty Bucket and Bale Spear. 6' Bushhog SQ720 Mower, Bushhog RDTH72 Finish Mower. Bushhog 3pth Log Splitter. Andy Tatro Grapple. Home Made 48" pallet forks.
    1966 Farmall 140 with cultivators and fertilizer attachment.
    1999 F250 LWB Ext. Cab 7.3L Powerstroke, ZF 6 Speed, Chip, Exhaust, Cool Air Intake.
    2009 Chevrolet Traverse
    1969 Mach1 Mustang 351W. Too much to list.
  7. #17
    New Member Hektor's Avatar
    Join Date
    Apr 2010
    Posts
    5
    I would like to use my 28 foot flatbed gooseneck with my tractor. I was hoping to haul hay (round bales) with it from the field to the barn. The trailer weighs 4900 lbs empty and is rated for 14000lbs. I've bought the trailer mover three point hitch attachment from Tractor Supply (rated at 2200lbs) and realize it is not safe to use for moving the trailer with any type of load.
    Is there any implement on the market that you can use with the tractor to move a loaded gooseneck trailer? (14000lbs) I don't want to use it on the road, just across fields.
    Thanks
    How heavy do you think your trailer will be when loaded with hay?
  8. #18
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,096
    Peoria IL
    New holland TC(33)
    i dont know why you would say that.
    if its the standard inverted T thingie for moveing goosenecks with add some reinforcement to it and use it!
    only thing i would caution is adding a brake controler to the tractor so you can activate the brakes on the trailer when its fully loaded even behind a tractor the size of yours.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  9. #19
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,380
    Southwestern, PA
    1958 Ford 961 Powermaster
    Quote Originally Posted by Dargo View Post
    Do you have a drawing for the hitch you made? I've been thinking of making one of these as soon as I get off the road and get home.
    Thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
