HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 08-14-2002, 08:19 AM   #1 (permalink)
Default Towing a trailer B2710
I usually use a drawbar on the 3 PH to tow a trailer. This works well. Sometimes, if the load is very heavy, the drawbar will rock backwards as I am towing the load. I have never had the trailer come loose YET, and I do not want it to. :~> Does anyone know of a device that will prevent the drawbar from moving back and forth? I would still like to maintain the tilt option if that is possible. I bought a "drawbar lock" from a local tractor dealer but it would not fit on the adjustable links of the 3 PH.
BTW, this is for a 2710 tractor.
Any ideas, suggestions, etc.. greatly appreciated.
greg
GregWatkins is offline   Reply With Quote
Old 08-14-2002, 08:24 AM   #2 (permalink)
art
Elite Member
Default Re: Towing a trailer B2710
You might just add a couple of tabs to go around or just over and under the three point hitch arms. Leave a little space just to make it easier to put on and off. This is not the best way to hook a trailer to the tractor although it is done quiet often.
art is offline   Reply With Quote
Old 08-14-2002, 08:43 AM   #3 (permalink)
Von
I made this hitch for my B2710 that takes a 2" reciever off of my truck. Works quite well when I have to move my 16' trailer around. I have seen these for sale in the Northern catalog.
Von is offline   Reply With Quote
Old 08-14-2002, 01:33 PM   #4 (permalink)
Tisco sell a little $15 thing that quickly attaches to the lift arm and supports the drawbar between the lift arms so it doesn't spin. I got mine at my dealer. Works great!!
bsauter is offline   Reply With Quote
Old 08-14-2002, 02:36 PM   #5 (permalink)
I've never actually hooked a trailer to it, but what about the draw bar built into the back of the tractor? Can't you put a ball on that? I guess the question is whether or not there is enough clearance for the tongue to get in there between the rear tires.
Alan L. is offline   Reply With Quote
Old 08-14-2002, 06:09 PM   #6 (permalink)
Epic Contributor
Bird's Avatar
Alan, I pulled trailers both ways with my B2710. The "swinging" drawbar (that doesn't actually swing at all on a B2710) works just fine, but I couldn't turn quite as tight with it or I would have gotten my rear tires into the trailer tongue.
Bird is offline   Reply With Quote
Old 08-15-2002, 06:28 AM   #7 (permalink)
Super Member
ronjhall's Avatar
greg
I have a similar hitch hookup as Von. I bolted mine to the draw bar in case wanted to move it to a bigger tractor. See attached picture. I still have not painted it yet. [img]/w3tcompact/icons/eyes.gif[/img]
My main use for it is to move my Bearcat chipper around. The tongue on this thing must weigh close to 100 lbs. [img]/w3tcompact/icons/tongue.gif[/img]
I use the offset hitch to get the ball under the tongue when trailer is low.
ronjhall is offline   Reply With Quote
Old 08-15-2002, 03:07 PM   #8 (permalink)
Thanks for the info. I will try Northern to see what they have OR I'll try to make one myself. Just gotta get that welder now
greg
Old 08-19-2002, 01:37 PM   #9 (permalink)
I purchased the setup from Northern Tool. Yes - it costs considerably more than if I would have done it myself, but I kept putting it off. Finally broke down and ordered the part - much better for towing than just the drawbar! I would definately not go back!
rdricks is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
