deerefan
I have a 06 F250 FX4 and noticed a small oil leak while under the truck. The other day, I saw a small oil spot on the front u joint of the driveshaft coming out of the transfer case. Upon further inspection, I noticed a drip forming on the exhaust manifold bolt (small) and a good film of oil in the engine valley (between the heads). The oil level in the truck was still normal, so I am not losing a lot of oil. Any thoughts on where it could be coming from? Is this common?
