Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Gold Member hrcarver's Avatar
    Join Date
    Apr 2010
    Posts
    446
    NC
    jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
    Default Having a 20' equipment trailer built, any options to add?
    After searching for months for a good and cheap used one exactly like I want it, I'm giving up and having a 20' 5 ton equipment trailer built. If you had it to do over, any options you would get(or leave off).
    Thinking about some fork... holders? Not sure what they are called, but a lil spot to load qa forks on the bottom/side of the trailer to save room up top. What is that called?
    There is also a 7' wide option, vs the standard 6'6" for $50. Useful or not?
    Besides that, was thinking LED lights would be better than crappy regular trailer lights.
    Anyone ever actually used a spare tire?
    The base 20' 5 ton(4 ton load) trailer for $2800 has 2' dovetail, pressure treated pine floor, two 5200 lbs axles with electric brakes on both axles, and fold up spring assist ramps.
  2. #2
    Join Date
    Aug 2006
    Posts
    737
    Buckhannon, WV
    1947 Ford 2N and 2003 Kubota B7500
    Default Re: Having a 20' equipment trailer built, any options to add?
    The fork storage sounds handy.
    I would add 6" of width for $50.
    I have used a spare and it is worth having for one reason. Wal-mart and most other tire retailers won't put anything but trailer tires on a trailer and they probably won't have one you like in stock, if any.
  3. #3
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,627
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel
    I wish ours was 8 foot wide.
    For about the same price you can get the 6,000 Dexter axles that will nearly offset the weight of the trailer. After getting a 13,000+ pound backhoe I am glad we have three 6K axles.
  4. #4
    Join Date
    Apr 2010
    Posts
    446
    NC
    I already have a 14k 20'x8.5' straight deckover tag along. I'm keeping it, but the trailer itself is half a load on my pickup, the beams on that thing must be 12" all the way around. Its basically only good for my one ton flat bed.
    I am looking for a pickup towable, lightweight trailer that is still heavy enough to haul a 45hp tractor with a couple implements. Spring loaded fold down ramps will be nice instead of lugging out the hide away ramps on my other trailer. I might be a chicken, but loading that deckover w/ no dovetail makes me nervous, not to mention curves on the highway with that tractor up in the air!
  5. #5
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,627
    Murray, KY
    Lower is better. The 6K axles while about the same price just gives more options and some margin against pot hole, etc damage.
    While our old F-700 is not as easy to drive in tight spots it has the mass and power to start and stop big loads.
  6. #6
    Gold Member
    Join Date
    Apr 2010
    Posts
    344
    As long as you're having it built to suit, you may want to have the builder add some steel up front to mount a nice winch to when the budget allows.
    Perhaps something like this one....a standard 2" X 2" receiver tube that would allow easy mounting/dismounting:
  7. #7
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,627
    Murray, KY
    brokenot that is a neat winch set up.
  8. #8
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    I would go 7' wide for $50. I did so on my trailer and glad I did. The winch plate is smart also. I had to add one to my trailer later on. Not a big deal but might as well get it done now. LED lights are also smart along with upgrading to 6K axles for little or no extra money. As for the spare I have use them on everything I owned except 1 truck. I must have bad luck but there is now way I would get a trailer without one.
    One other neat option one of the boat trailer manufactures I deal with has is a full set of extra bearings/races with a seal, tools needed to change it, a 6 ton bottle jack, and a lug wrench all in a plastic box mounted on the inside of the tongue.
    Chris
  9. #9
    Join Date
    Apr 2010
    Posts
    446
    NC
    Might just be my guy, but from 5200 lb axles to 6000lb axles is an extra $500???
    7k is $250 over that. For a $2800 trailer, seemed like a steep jump for my use.
  10. #10
    Super Star Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    10,277
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Quote Originally Posted by brokenot View Post
    Excellent idea on the winch. I like that set up, too.
Similar Threads
  1. Trailer Came Loose
    By Bird in forum Trailers & Transportation
    Last Post: 11-27-2017, 06:13 AM
  2. Equipment trailer, 16' vs 18' dilemma
    By JB4310 in forum Trailers & Transportation
    Last Post: 03-07-2009, 12:14 AM
  3. Trailer Troubles / Decisions
    By Yooper3830 in forum Trailers & Transportation
    Last Post: 08-10-2005, 10:16 PM
  4. Trailer?
    By tdenny in forum Trailers & Transportation
    Last Post: 06-20-2002, 12:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
