Page 2 of 12 FirstFirst 12345 ... LastLast
Results 11 to 20 of 117
  1. #11
    Platinum Member Big Bri's Avatar
    Join Date
    Jun 2009
    Posts
    926
    Kubota MX5100
    Default Re: The Gatormade expierence.
    on the 4th pic on the top. . . are the drips running up? thats weird! Sorry for your trouble. I hope they make it right for you good luck.
    Brian
  2. #12
    Silver Member 6dog's Avatar
    Join Date
    Sep 2009
    Posts
    137
    Ellicott City, MD
    2003 JD 4110 w/ Curtis Cab
    "WOW", is about all I can say.
    2003 JD 4110 - Loader / Backhoe / 60" MMM / 54" Snow Blade / Curtis Soft Cab
    1989 JD 332 - 50" deck
  3. #13
    Gold Member tractorboy5500's Avatar
    Join Date
    Dec 2005
    Posts
    365
    Conroe TX
    Mahindra 5500 4WD, 275 FEL
    Sorry for all your trouble Davy, at least your posting will only make me really inspect mine when it is finished being built, the only down fall i have is that i have put $1000.00 down to start building the trailer. I have asked questions about the wiring and the differnt options that i have added. I ordered 12k axles, they said that they use dexter axles, so i went online and found the differnts on 10k and 12k axles, so now i will know what to look for. And i havent asked about the brand of tires, i have been looking from other post on the carsile tires, hope i get some good ones, but i will ask what kind of warranty might come with them if any.
    Sorry for all you trouble, but you only made it better for me when i go pick mind up in about 5 weeks. thanks.
  4. #14
    Gold Member HarleyScooter's Avatar
    Join Date
    Jun 2004
    Posts
    265
    Canton, Ohio
    Kubota/ BX2230
    tractorboy5500,I bought a Gatermade 16'- 7K trailer a month ago and here are a couple of things I found out. They advertise a wiring harness special for the trailer? Well they use a wire like a extension cord but with 6 or 7 wires in it and just tap into that with scotch locks. I removed about 18 of those things and soldered/ shrink wrapped all the wiring. As far as the Dexter axles, well at least on my 3500# brake axles they are Dexstar and made in China, and so are the wheels, I think the tires are from China too. For the price it cost, the welds are good and so is the paint. I like the trailer and would buy it again. I don't like the China products but I guess that's what you get when you try to save some money?
  5. #15
    Join Date
    Dec 2005
    Posts
    365
    Conroe TX
    Well i didnt say in my last post, i ordered a Longhorn trailer, from emory Tx, i read all of there options and what all they had, but from listening to all you guys, i will look at everything when i go pick it up, i looked at the Gatormade trailers, i like the way they look, and also they look tough built, but seems like some of there workmanship isnt that great, at least the things that are not right can be fixed fairly easy.
  6. #16
    Join Date
    Dec 2005
    Posts
    365
    Conroe TX
    Quote Originally Posted by HarleyScooter View Post
    Thanks for pointing out the Dexstar axles, instead of the Dexter axles, i have to right that one down, I have the email from Longhorn trailer that said Dexter 12K axles, Thank you very much sir.
  7. #17
    Gold Member
    Join Date
    Nov 2005
    Posts
    305
    Central Indiana
    New Holland TC45DA SS
    Dexter - Dexstar ?! That's about as bad as the sticker on the back of the neck that has GATor on it that looks like the CAT symbol. CAT - GAT. I peeled mine off of there. I guess when a salesman says a trailer has Dexstar axles under it, it sounds like he is saying Dexter.
  8. #18
    Gold Member Mike Costello's Avatar
    Join Date
    Nov 2008
    Posts
    416
    Dunnegan, Missouri
    Kubota L4400HST, R4 tires, L2228 Quick-attach setup
    When a salesman or company starts playing with words, its time to move on. Its deception at its worst--no excuses! So is quality--its either there or not there, but don't blow smoke up my skirt and deliver junk that I have to fix. Gatormade needs to man up about the problems on this trailer or give him his money back. Mike.
  9. #19
    Gold Member davygp38's Avatar
    Join Date
    May 2009
    Posts
    478
    where NY,NJ, and PA all meet
    Kubota L4400
    Quote Originally Posted by Big Bri View Post
    The drips are not running up, I had to hold the camera on a weird angle so the drips would show up in the pic.
  10. #20
    Join Date
    May 2009
    Posts
    478
    Kubota L4400
    I spoke with paul at gatormade, they are sending me new tail lights. and an owners manual. They went with led lights, that were supposed to fit those holes, but obviously did not. I am supposed to find out soon if I will get some "other consideration." I will keep you posted. I have a question for you guys. What oil is used in the wet hubs on these trailers? Paul at gatormade told me 90 weight, but the oil in there looks a lot thinner. I was thinking of using the synthetic stuff I put in the rear on my truck. what do you think?
Similar Threads
  1. Gatormade trailers still gets C grade
    By Newblue in forum Trailers & Transportation
    Last Post: 12-20-2012, 05:54 PM
  2. Gatormade
    By Bentwrench in forum Trailers & Transportation
    Last Post: 08-19-2012, 05:18 PM
  3. Buying Advice gatormade trailers
    By 747driver in forum Buying/Pricing/Comparisons
    Last Post: 04-20-2010, 06:33 AM
  4. Feedback on Gatormade Trailers, please.
    By nate_m in forum Trailers & Transportation
    Last Post: 11-21-2008, 06:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
