Spanky100
- Joined
- Dec 19, 2002
- Messages
- 215
- Tractor
- Current Kioti CK27HST and Cub Cadet 1810. Previous NH1510 Hydro, AC D14, Oliver 1355?, and JD 314 Lawn Tractor
Looking to purchase an enclosed trailer to haul and winter store a soon to be purchased tractor, front end loader, and rear rotary cutter. The equipment will be used about 6 months of the year at home and vacant land that needs to be cut (5 acres to cut)a couple times a year to keep it from getting overgrown.
The highest weight tractor I am considering is a Kioti CK35 with 130 loader and 5 foot rotary cutter. The weight (lbs) is 3200 tractor, 800 loader, and 800 for 5 ft rotary cutter. Total say around 5000 lbs. Likely will need at least a 7 ft by 22 ft trailer to fit in and position tractor for weight distribution. I suspect this size trailer would weigh at least 2500 lbs empty. Tractor and trailer at least 7500 pounds. Thus likely would need a trailer with two 5200 pound axles with brakes for both axles. Estimated total towing miles per year would be 3000.
Most of the enclosed trailers I see have 3/4 plywood floor over 16 to 24 inch on center crossmembers. D-rings are installed to secure load. My initial concern is: are enclosed trailers typically used as car haulers sufficient strength to haul CUT with implements? Should I get "barn doors" and use detachable ramps in place of the ramp door.
Looking for other thoughts and advice to make the correct decision. Any manufacturers come to mind. Do the V-nose trailers reduce the wind drag much or are the just used to add storage at the V section of trailer frame.
Thanks
Thanks
