HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-28-2002, 03:21 AM   #11 (permalink)
Default Re: How to tow a trailer?
OK, here is the poorboy solution that I use that will work fine for most applications. While the 3-pt connection is the best, most that are available are fairly expensive for something that is so simple so here's what I do. I use the drawbar. To keep the drawbar from twisting under a heavy load I simply took a piece of 2" aluminum angle iron about 12-14 inches long I had laying around and drilled a hole in one end the same size as the holes in the drawbar. Then I took a 3/4" bolt and attached the angle iron one to one of the outside holes on the bottom side of the drawbar. I then position the other end of the angle iron under the lift arm forward of the lifting point and secure it there with a piece of wire. This keeps the draw bar level and it cannot rotate when a load is applied to the ball. The only drawback to this set up is you will not be able to raise your lift very high and have it remain level. But it is much cheaper than a $200 3-pt. hitch and you still have about a 1/3 of your usable lift range for hook ups. I have used this method on many tractors with many different size and weight trailers and never had any problems.
lpigott is offline   Reply With Quote
Old 09-28-2002, 06:45 PM   #12 (permalink)
Super Member
Inspector507's Avatar
Get a drawbar lock..........cost $20.00.
Keeps the drawbar from pivoting.
Inspector507 is offline   Reply With Quote
Old 09-28-2002, 09:36 PM   #13 (permalink)
Gold Member
That would be great!!!! I was at Agri-supply today and didn't see anything that resembeled that. Where could I get one from? thanks again.
manganos is offline   Reply With Quote
Old 09-29-2002, 12:10 AM   #14 (permalink)
The drawbar locks work great but all the ones i've seen will not fit on the shorter BX lift arms because the check chain connecting point is in the way. Thats why I did the angle iron trick. It also does not get in the way so It pretty much stays on mine unless i need to hook something on the 3-pt. Their are some homemade 3-pt reciever ideas if you search under customisation
Old 09-29-2002, 10:53 AM   #15 (permalink)
Super Member
Do a search on "Drawbar Lock" on the web. <A target="_blank" HREF=http://www.unionfarmequip.com/store/linkage/drawbars.html>Union Farm Equipment</A> is one place to order from...$19.62. But as has been mentioned, may not work on the shorter arms of the BX 22.
Jerry
Old 09-29-2002, 10:58 AM   #16 (permalink)
Super Member
Also try Lowery's in AL. Do a search on "Lowery's" here on TBN. This looks good to me for $36.00
<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-58954-3pttraler.jpg>Lowery's Towbar</A>
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
