#11 (permalink) |
New Member
JackIL,
You've really peaked my interest. Any chance you could post some closeup pictures of the trailer. My brother-in-law is into welding and I think we could tackle a project like this. I have an older trac-vac tow behind that I can pull the vacuum off of. Thanks, Shoppintractors Don |
#14 (permalink) |
New Member
Here's a link to Country Manufacturings trailer page <A target="_blank" HREF=http://www.countrymanufacturing.com/frameset.htm>Country Manufacturing</A> Scroll down to wagons & trailers on the left side of the page. These trailers come in 6ft. or 7 ft. lengths and are 38 inches wide.
#15 (permalink) |
New Member
Seems like the trailers from Country Manufacturing are like the old barge wagons or flare box wagons. Could farm trailer running gear be made into a dump trailer? Gear or hydraulic to trailer bed and a hinge pin. Not sure how the center of gravity changes with the height of the floor of the trailer.
Around here, farm trailer running gear with a hay wagon set-up or old gravity boxes, even chopper wagon running gear can be picked up at auctions or implement dealers very reasonable. Not sure if this could be done. |
#16 (permalink) |
New Member
I kept thinking about this. Then I did some searches. The only examples with photos that I could find were scale model toys. This was the best. It actually gave John Deere model numbers.
model 963 running gear + model 150 hoist = a cheaper dump trailer While it is a photo of a scale model toy, it does illustrate the idea. I'm sure other manufacturers offered the same type set-up. While doing the searches under "barge wagon" a number of hits came back for auctions. This gets me thinking. A trailer like this would be ideal for hauling firewood, compost, leaves, kids - whatever. Might have to start looking around...maybe find one. Even build one. Local farm trader newsletter has NEW 5 ton running gear with rims, no tires for $459. Used hay wagon trailer in same publication for $150. Trip to the scrap yard might be in order. |
#17 (permalink) |
I've been kicking around converting my 6 x12 single axle trailer (2X4X1/4" wall tube frame)
to a tandem axle dump trailer. Dad has a couple sissor hoists from 2ton trucks. I need to replace floor w/ 3/16 steel plate and build removable 1/8" steel sidewalls. Then build new subframe w/ tongue and w/ axles on it and hinge in back. A 12v pump w/ quick-disconnects to use on truck then use remote on tractor. Then I had an idea, Found some used 10' contractor dumps (low side walls) $300.00 didn't see yet but could be poor shape. U could do same thing w/ wagon gear and find cheap dumpbed and put together. |
#18 (permalink) |
Here is a web site that has 'ready made' or will custom make a trailer for you. A high floatation (tires) tandem trailer for under $800. Add a hydraulic sissor-type lift for about $400! Sent to you via UPS package(s).
Check it out. http://www.autosalvage-sas.com/carts.html Dave |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
