HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-04-2002, 06:29 PM   #1 (permalink)
Default Lawn Vac Trailer Details
This is in response to Don and others in the thread "A Cheaper Dump Trailer" who requested that I post more details of the lawn vac trailer system I built starting from a Country Manufacturing 6 foot trailer. I took several pictures to illustrate the construction. I hope that posting them here in a new thread does not overstep the bounds of reasonableness. If so I appologize in advance.
The first is an overall view of the tractor and trailer. The tractor is a Ventrac 4200 (31 hp) with 72 inch deck. The trailer is based on a Country Manufacturing 6 foot tandem axle trailer, and the vac system is an EZ-Vac (now called Bluebird International). I prefer the articulated 4WD tractor with dual wheels for safe and secure operation on steep hills. The tractor can operate on slopes of 30 degrees. I have not taken the trailer over 20 degrees.
Jack
JackIL is offline   Reply With Quote
Old 10-04-2002, 06:31 PM   #2 (permalink)
Default Re: Lawn Vac Trailer Details
Close up of left side of trailer. Nominal dimensions of bed: Length = 72 inches, Width = 39 inches, Height = 34 inches. Exhaust chute is full width and tapers upward to a 4 inch tall opening across the back. Under the chute the entire top of the box is cover with mesh screen to minimize blowout.
Old 10-04-2002, 06:33 PM   #3 (permalink)
Left Turn. Note that the steering pivot for the trailer is directly below the vac system and not at the tractor hitch.
Old 10-04-2002, 06:38 PM   #4 (permalink)
Same turn, but seen from right rear.
Old 10-04-2002, 06:39 PM   #5 (permalink)
Steering Hinge details.
Old 10-04-2002, 06:41 PM   #6 (permalink)
Trailer Hitch to tractor. Note the control arm on the right. It is simply the top link for a Cat 0 3 point hitch. Its purpose is to prevent steering from occurring at the tractor connector, but it does allow roll of the trailer with respect to the tractor.
Old 10-04-2002, 06:44 PM   #7 (permalink)
Top view of hitch. Note that the axis of the pin on the sway bar passes through the center of the ball joint.
Old 10-04-2002, 06:45 PM   #8 (permalink)
Sharp right turn. Hose does not hit trailer.
Old 10-04-2002, 06:49 PM   #9 (permalink)
Sharp left turn. With the hitch system it is possible to make sharper turns than would be possible by just having a single piece long tongue on the trailer.
Old 10-04-2002, 06:51 PM   #10 (permalink)
Dumping with hydraulic cylinder. Max bed angle is 47 degrees.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
