Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Silver Member RedRock's Avatar
    Join Date
    Aug 2010
    Posts
    103
    Texoma
    Mahindra 2816 Gear
    Default Trailer Weight Distribution - Single axle
    This is the first time I've had to use my new trailer with any significant weight on it. All my numbers check out, 3500lb single axle, 900lb trailer, truck towing cap is 5,100lbs. The load is a tote container of 330 gallons of good ole H20 weighing in at 2,753lbs.
    My truck's OM says I should have 9 to 11% of the total trailer weight not to exceed 350lbs on the hitch , so I'm shooting for around 10% tongue load.
    Here's the tough part, I'm not sure how you determine the position over the axle that gives me this 10%. I have to get it right to begin with because once I fill this puppy up, I really don't want to drain it to make it light enough to start over. Any help from you old pros is greatly appreciated.
    Take a look at the pics and let me know if I'm close where I'm at or if I need to be looking for a tongue scale that can measure up to a 1/4 ton?
    Attached Thumbnails Attached Thumbnails Trailer Weight Distribution - Single axle-cube-001-jpg   Trailer Weight Distribution - Single axle-cube-003-jpg
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default Re: Trailer Weight Distribution - Single axle
    You can move the tote slightly once loaded with a come along. Its easier than you think. I have moved a 6,000# rock on my wood trailer very easily.
    What I would do is place the tongue on a piece of 4x4 supported one end with your bathroom scale and a scrap of wood the same thickness on the other. The use of the pipe like in the pic is not that crucial. I have done it both ways and the error is negligible. Fill the tote with water and you should read 1/3 the weight on the scale. In your case somewhere around 120#
    I think you need to come forward 6" or so. To little tongue weight is 100 times more dangerous than too much.
    Like this.
    Tongue Weight
    Chris
  3. #3
    Silver Member VitaBene's Avatar
    Join Date
    Oct 2009
    Posts
    207
    Moultonborough, NH
    Kubota L3430
    Quote Originally Posted by Sandusky View Post
    You look fine in the pic. When you crank the trailer down onto the hitch make sure that you get an inch or so of sag.
    L3430HSTC w/ LA723 loader, Woods RD7200 finish mower and Kubota L2174A front mount snowblower
  4. #4
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    One other thing is strap it down good. I would go though the bottom of the tote where you pick it up with a fork lift and also from each of the top 4 corners with some lighter straps to keep it from tipping.
    Chris
  5. #5
    Join Date
    Aug 2010
    Posts
    103
    Texoma
    Mahindra 2816 Gear
    Quote Originally Posted by Diamondpilot View Post
    Tongue Weight
    Chris
    Thanks Chris, thanks for the tip using the come along and the tongue weight link.
    2010 Mahindra, 2816 4WD Gear w/FEL
    AG-Meier Brave Rotary Cutter
    Armstrong Ag 5' Box Blade
    Armstrong Ag 5' Disc
  6. #6
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,206
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Here are directions to use a standard bathroom scale to measure tongue weight: Tongue Weight Scale
    Take that, measure empty, fill the container 1/4 of the way with water and use your straps on the trailer uprights to pull the container forward or backward as needed.
    Edit: Whoops, looks like Chris replied with the same idea between when I loaded this thread and when I replied
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  7. #7
    Super Member bp fick's Avatar
    Join Date
    Aug 2009
    Posts
    5,714
    Beaver Creek, Northern Michigan
    Kubota BX2360
    Chris
    Chris is right. Move it forward a smidge. I have a very similar trailer and cheating toward tongue weight versus the wig wags caused by having it just bit too far back is an easy choice. Go for the tongue weight. Wig wag is not fun.
    BP
    "Some chickens, some gardens and a Kubota."
  8. #8
    Gold Member firefighter jim's Avatar
    Join Date
    Feb 2009
    Posts
    491
    Quote Originally Posted by VitaBene View Post
    Ditto that. The center of your load is favoring just forward of the axle. Looks good.
  9. #9
    Join Date
    Aug 2010
    Posts
    103
    Texoma
    Mahindra 2816 Gear
    Interesting setup in the drawings for the bathroom scale.... those "pipes" look tiny. I have a couple of pieces of 1 1/4 " pipe to use but getting them level and balanced makes me think of one of those circus acts I saw as a kid, I may have to find smaller diameter pipe for the scale test.
  10. #10
    Join Date
    Aug 2010
    Posts
    103
    Texoma
    Mahindra 2816 Gear
    Here's a shot of the bathroom scale in action, the brick under the board is not touching. I almost spent another $20 on an analog bathroom scale but this digital worked out OK in the end. I ended up stopping at 300 gallons times 8.3 = 2,490lbs. , the scale showed 104lbs. , multiplied by 3 = 312 lbs. tongue weight. (well under my 350 limit)
    I moved the load forward about 6" as recommended and have it all strapped in for a snug ride.
    Now the main reason I bought this tank was to water in the crusher base I spread for my metal building to be built. We've had quite a drought in certain spots of far North Texas, so I wanted to harden it before the building went up. All summer long its rained within 20mi. around but not a drop for us. Well, I wasn't 2 sentences into this post when down comes the rain, gotta be at least an inch at this point. For those of you in Nortex and S. Ok. needing rain, your welcome
    Attached Thumbnails Attached Thumbnails Trailer Weight Distribution - Single axle-cube2-001-jpg   Trailer Weight Distribution - Single axle-cube2-002-jpg
Similar Threads
  1. Horse trailer ?
    By ChrsDrn in forum Trailers & Transportation
    Last Post: 01-15-2010, 09:53 PM
  2. size of trailer for TC33?
    By global312 in forum Trailers & Transportation
    Last Post: 05-30-2009, 02:00 AM
  3. Trailer Weight Distribution Question
    By EastTnFarmboy in forum Trailers & Transportation
    Last Post: 11-28-2007, 02:33 PM
  4. Axle weight vs. fluid
    By LWB in forum John Deere Owning/Operating
    Last Post: 03-31-2007, 08:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
