jmanatee2
Gold Member
All of the dual cylinder hoists I have seen on grain trucks were driven off a common manifold or wye. That does little to keep the bed from twisting. Kinda like squeezing a balloon. If you squeeze one end harder than the other, the other gets bigger.
Dave
I was going to say this, both cylinders are tied together so the pressure will go to the side with the least resistance. I am not sure but what two cylinders could twist it more.
I have a Bri-Mar 10k lb 6 x 10 dump single cylinder,... I love it. Only thing I would change is rear door. Mine only does gate or spreader mode. I have seen rear doors that do gate/spreader and barn door
