Results 21 to 30 of 37
03-20-2012, 05:13 AM #21Gold Member
- Join Date
- Sep 2008
- Posts
- 314
- Location
- Central Virginia
Re: New trailer for tractor hauling
03-20-2012, 09:06 PM #22Platinum Member
- Join Date
- Oct 2002
- Posts
- 901
- Location
- Lancaster, Ohio
- Tractor
- Caterpillar 277
03-20-2012, 11:29 PM #23Silver Member
- Join Date
- Mar 2011
- Posts
- 130
- Location
- Ironwood Michigan (Northern Michigan...by Lake Superior and Wisconsin)
- Tractor
- JD4210, ASV PT100, JD 50D, JD 350C, Komatsu D65, JD Gator 825i, PB100, Kubota 900 RTV, Metavic, Briamar dump, F350 and 450.
I am looking at 32 ft hydraulic Dove tail from PJ, it weighs 7310 pounds and has is 25k GVW with 12K axles.
03-21-2012, 06:16 AM #24Gold Member
- Join Date
- Sep 2008
- Posts
- 314
- Location
- Central Virginia
03-21-2012, 06:29 AM #25
03-21-2012, 02:41 PM #26Gold Member
- Join Date
- Jan 2008
- Posts
- 363
- Location
- Western PA
- Tractor
- John Deere 5083E MWFD, Kubota L3400 HST
I have a 2011 Moritz 20+5 with a manual beaver tail so I can covert to a straight decked 25 footer. They also have a low profile option to get your deck height down to 33" like mine. Its a stretch but you can high step onto it from the ground! Its rated at 14.5K which gives you plenty of room for a dually to get to stay under your 26k number! They also let you get 7k or 8k axles under it. I had them put a 2" receiver welded inbetween the uprights so i could slide in a 12k winch just in case! I put the dual 600CCA batters in the tool box right below it!
'11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR),
'01 International 4700 LP, DT530, Allision 3000, Air Ride, Crew Cab
'11 Moritz 20+5 14.5K GN with adj. Tail
'95 CR 500
FIL-JD 4020; Ford 9600,5000
03-21-2012, 06:37 PM #27Platinum Member
- Join Date
- Oct 2002
- Posts
- 901
- Location
- Lancaster, Ohio
- Tractor
- Caterpillar 277
2002 Kioti DK65 SOLD
2006 Country Clipper "Charger"
03-21-2012, 06:48 PM #28
03-21-2012, 08:10 PM #29Gold Member
- Join Date
- Sep 2008
- Posts
- 314
- Location
- Central Virginia
03-21-2012, 08:37 PM #30Platinum Member
- Join Date
- Apr 2010
- Posts
- 975
Here is what I think.
1) Trailer 10,000 pounds or less, truck can be 26,000 pounds or less for a total of 36,000 pounds -- no CDL. Same trailer, but truck 26,001 or more---- NEED CDL.
2) Trailer 10,001 pounds or more, total of truck + trailer (actual or tagged weight) has to be 26,000 or less for no CDL. Same trailer, but total of truck, trailer 26,001 or more --- NEED CDL.
The weights listed are actual weight or tag weight -- which ever is more. So if the actual weight of the trailer is 9900 and the actual weight of the truck is 10,000 but the tag weight is 18,000 trailer and 14,000 truck -- a CDL would still be needed.
Did you win your bet or lose?
OP's original post #1 he stated he was looking to get a trailer in the 17,000 to 18,000 pound (gross) range. The trailers with that capacity are (empty) in the 7-8,000 pound range for a capacity in the 10k area. Trucks that can pull 17-18k will have tagged rating of 10-14k. Take the minimums and that is still OVER 26k with a trailer over 10k --- that would need a CDL. At least here in WI.
Similar Threads
Swapt Trailer for Trailer
By deepNdirt in forum Trailers & TransportationReplies: 17Last Post: 04-29-2011, 09:52 PM -
2310TLB Trailer ball modification
By dragula in forum Massey Ferguson Owning/OperatingReplies: 2Last Post: 11-07-2007, 09:51 AM -
Need Dump Trailer info.
By Pird in forum Trailers & TransportationReplies: 32Last Post: 03-20-2005, 06:57 AM -
dump trailer
By avclay in forum Trailers & TransportationReplies: 17Last Post: 06-08-2004, 12:29 PM -
Trailer?
By tdenny in forum Trailers & TransportationReplies: 89Last Post: 06-20-2002, 11:51 AM
