Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,933
    Central Ohio
    Kubota MX5100
    Default 2005 Dodge 3500 Cummins Fuel Milage
    Well, this is kinda an update to this thread http://www.tractorbynet.com/forums/t...eal-truck.html But I figured I'd start a new one since that one is old.
    I gotta say, The milage is a little disappointing, but livable, but what is really disappointing is how far off the computer is Every other vehichle I have owned, including other dodges (not diesels though) has been spot on. My last 2003 chevy even had told how many gallons was used, and that was right on within 0.1 gallons for a full fillup.
    Anyway, we took a road trip today to newport aquarium. I filled up before we left. I still had ~1/2 tank and 268 miles on the odometer. That 268 miles was mostly working the truck. Hauling loads of firewood as can be seen on my other threads, towing the kubota to a buddys and back to do some work, and scrapping a couple of cars. But the cars were only ~3000 lbs and the kubota weighed ~ 4500 plus my 2700lb trailer. So not really a heavy load for the truck, but no highway either.
    That 268 miles took 23.7 gallon of fuel for a calculated figure of 11.3MPG, which I thoug was low. I was expecting ~ 14-15 given the loads and driving I did, and the computer said 15.6, so it was off by a good bit.
    Anyway, we filled up right before getting on the freeway, and again right as we got home. Cruise was set @ 71 on the way down and 75 on the way home. Mostly flat ohio freeway right down I71 from 140 exit to just across the river into kentuckey. 284.6 Mile round trip. 15.89 gallons to top off.
    Calculated figure of 17.9MPG. I can accept that for highway, but the computer showed 20.4
    So how many of you fellow Dodge CTD owners have actually hand figured, and compared to the computer???
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  2. #2
    Silver Member chevy292's Avatar
    Join Date
    Nov 2009
    Posts
    109
    Ma.
    Kioti DK35 TLB
    Default Re: 2005 Dodge 3500 Cummins Fuel Milage
    My '05 trip computer says 22.2 anytime I'm doing highway miles. Hand calculated is 19.8. Towing my machine around town to jobs I average 15.7. I have found that the trip computer is much more accurate when I don't reset it for a couple months.
    DK35 TLB. 6' Box Blade, 60" flail mower
    1963ish JD 2010 TLB
  3. #3
    Join Date
    Apr 2008
    Posts
    17,933
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by chevy292 View Post
    Thats still about 2 MPG better HWY
    And over 4 MPG better with a heavier tractor than me
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,491
    Somewhere north of Roseau, MN
    Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
    I've always found the computer to be very optimistic on my '05 Dodge 2500 Cummins; sometimes by as much as 5 mpg. I've hand calculated my mileage ever since I discovered that. My camper towing is about 11.5. Highway is about 17 and my typical everyday driving averages around 14-15. Lots of driving around town can drag it to as low as 12. I was kind of hoping for a little more, but it's still much better than my '94 Suburban w/ 5.7l, and also better than my Dad's 7.3 Powerstroke, so I can't complain too much.
    Now, my brother's '03 Cummins 3500 constantly gets 4-5 mpg better than mine, but if you look at the specs, it's a noticeably milder engine, so that's to be expected. You don't get more power out of the same engine for nothing.
    I'm begining to think it's just the nature of the beast.
    Joe
    Joe
    Fordson Major Diesel: Case 3-bottom Trip Plow, Case 12' Trip Field Cultivator, Kewanee 130 Disc, John Deere 1209 Mower Conditioner, John Deere 594LW Side Delivery Rake, New Holland Hayliner 273 Baler, 18' Spike-Tooth Harrow
    Ford 1510: Du-Al 105 Loader, "The Thumb" Grapple, Bush Hog RBC60 Rear Blade, Woods HC54 Rotary Cutter, Tarter 5' Heavy-Duty Hinge Back Box Blade, Buhler Farm King Y600 Snowblower
  5. #5
    Join Date
    Nov 2009
    Posts
    109
    Ma.
    Kioti DK35 TLB
    I'm really surprised there is that much difference between trucks. Although I did fail to mention that I have a Bullydog PMT installed in my truck. I have to say I was skeptical at first but the power gains were undeniable. I did notice an improvement in the mileage while while both towing and highway driving. However just around town driving didn't improve at all.
    1963ish JD 2010 TLB
  6. #6
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Never had a Cummins but like you every other truck was pretty much spot on, mainly Fords and GM's but also a Honda, Toyota, Nissan, ect thrown in there.
    No more the .25 mpg error in any of them.
    Chris
  7. #7
    Join Date
    Nov 2010
    Posts
    653
    Marshall Texas
    Kubota L4400
    Quote Originally Posted by Marveltone View Post
    Joe
    I ahve found it to be more accurate when I dont mess with it... TBH, I dont even look at it unless we go on a LONG trip... like atleast 250 miles..
    The 03 models had less stringent emissions and lower hp, so like MARVELTONE stated, nothing is free.. Also, what differential gears do you have? 3:42, 3:73, 4:10???
    @When driving across Texas, I can get 19-21 MPG out of a 3:73 equipped 06 Ram 2500 4x4 QC.. this is hand calculated and running completely stock, no power adders and on stock tires. If you are looking for some added fuel efficiency, buy a Smarty Jr. Set it on SW1 and forget about it.
    Kubota L4400 GST
  8. #8
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,668
    central Wisconsin
    Kubota B7800, B26 TLB
    I have a Bully Dog installed as well. I have it set to max power and realize better fuel economy at that setting. You just get used to using only the top 1/8th of the petal but really nice when you HAVE to get on it to have the rest in reserve.
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  9. #9
    Join Date
    Apr 2008
    Posts
    17,933
    Central Ohio
    Kubota MX5100
    I believe it is 3.73 gears
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  10. #10
    Member
    Join Date
    Feb 2007
    Posts
    47
    My computer is always off by about 4 mpg... I just know that when I look at it and don't worry about it... I average about 18 - 19 empty and 12 - 14 pulling the tractor or travel trailer. I do have the 05 2500, 6 speed and about 136k on the engine.....
    Tim
Similar Threads
  1. ALGE IN DIESAL fuel!
    By toolaholic in forum Oil, Fuel & Lubricants
    Last Post: 04-11-2012, 10:25 PM
  2. 2005 Dodge 3500 4x4: Front ride height???
    By LD1 in forum Trailers & Transportation
    Last Post: 08-21-2011, 04:55 PM
  3. Dodge 2005 - 2500 Diesel
    By alpaca-farmer in forum Trailers & Transportation
    Last Post: 04-05-2010, 08:03 AM
  4. Oil & Fuel Diesel additive or not?
    By Jeffery8mm in forum Mahindra Owning/Operating
    Last Post: 05-14-2009, 11:54 PM
  5. Oil & Fuel Which fuel should I use
    By DDT in forum Owning/Operating
    Last Post: 02-02-2003, 09:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
