'99 F250 7.3L PSD Issue- Suggestions
   / '99 F250 7.3L PSD Issue- Suggestions #1
drivadesl
Gold Member
Hudson Valley, NY
New Holland TN-70A, Kubota U-35 Mini-Ex,SCAG Wild Cat, Cub Cadet 109
My truck has about 120K miles on it. I bought as lease trade in with 40K miles. Have performed the normal maintenance split between myself and Ford dealer. Also, use diesel fuel additive every 6 months or so if it matters. Put maybe 10k miles on it annually.
I noticed a little bit different of a sound in the idle in the past few months. Nothing major, but just something different. Normal around town driving truck felt fine, normal power and fuel consumption.
While trailering my tractor yesterday, roughly a 10K lb load, it pulled fine on normal grades, but when I tried going up a pretty steep mountain that I've done many times before with same trailer, it pretty much came to a stop. No power. Had the pedal to the floor going 1mph....in low gear. Engine did sound like it was laboring a bit, but didn't blow smoke or otherwise show any other signs of issues.
After unhooking trailer I was able to drive home 90 miles with no issues. Truck felt normal. Leaves me scratching my head. :mad:
Tranny fluid was changed in the spring, and did not smell burned and was at proper level. Same with oil, fuel filter and air filter, all changed within past 5k miles. Trailer was inspected a few weeks back no issues. Tires were inflated to 80lbs, and were not overheated or dragging as far as I can tell.
Did a cursory inspection of the engine, nothing appeared obviously wrong. Turbo hoses showed no obvious cracks or damage.
Any ideas of where to start? Possible fuel injector issue?? Any suggestions on what to check before I take it in? Thanks.
   / '99 F250 7.3L PSD Issue- Suggestions #2
change the cps sensor
   / '99 F250 7.3L PSD Issue- Suggestions #3
Cooling fan relay went on ours, and the cpu put the truck into limp home mode. Would not pull the trailer, and would go no faster than about 50km/h unladen.
   / '99 F250 7.3L PSD Issue- Suggestions #4
It is not the CPS (that's an all or nothing thing) and there is no coolant fan relay. Did you get any check engine lights? No smoke and no power means you have a fuel supply issue. Change the fuel filter again, it only takes one tank of bad fuel to plug up the filter. The fuel pump is suspect at this mileage as well, it is frame mounted and is supposed to make 70 psi in the system.
   / '99 F250 7.3L PSD Issue- Suggestions #5
Fuel and injector pump are both suspect to me at this mileage. Neither were designed for ULSD. I would highly recommend a lubricity additive at every fill up, rather than every 6 months. I like Power Service,though it is spendy.
   / '99 F250 7.3L PSD Issue- Suggestions #6
Sounds like a fuel delivery problem...
My fuel pump puked out couple years ago...
They can't take that ultra low sulfur diesel...
When mine went out it was like turning off a switch...
Nothing...
I would thing you may have an injector failing...
   / '99 F250 7.3L PSD Issue- Suggestions #7
I help drive with a 2000 7.3 and your description could be fuel filter and water in fuel.
Remember filling tank in St. Louis and going west at every hill had to pull over and drain filter. at Springfield unloaded the cattle and returning toward Ill. no problems. Again loaded the trailer with cattle and no problems until hill climbing and engine would just almost stall. got to where changing filters didn't correct . At Ford Service dept they found the filter into the injector pump was also clogged.
Now have 270K and engine still runs good. So my learned skill of draining fuel filter and replacing filter haven't been needed.
Hope this helps.
ken
Thanks for the great replies. Sounds like fuel filter is easiest place to start. How do you test for fuel pump and/or injector issues??
There were no dash lites on at the time.
It must be a minor issue, since the truck pulled the 10K lb load fine until the big hill, but need to find out what it is....
   / '99 F250 7.3L PSD Issue- Suggestions #9
Throttle position sensor, i think your truck has one. My 97 F150 did the same thing and the tps was the culprit.
   / '99 F250 7.3L PSD Issue- Suggestions #10
The 7.3 diesel does NOT have an injection pump nor does it have a throttle position sensor. It is a diesel with no throttle plate. There is a throttle pedal location sensor in the cab that is not typically an issue.
Fuel filter is right on top and easy to swap. You can even check it for muck covering the element since it is a naked element and look for muck/water in the bottom of the bowl. There is a fuel bowl drain lever, yellow and on the back of bowl, to just dupm out the fuel bowl and maybe observe water or muck.
If the engine idles smooth (for a diesel), starts well, and runs well then your injectors are fine. You aren't likely to loose all injectors at once. You have a fuel system failure so the big single parts are the culprit.
