Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Gold Member
    Join Date
    Dec 2004
    Posts
    383
    Davidsonville, Maryland
    John Deere 4400, '48 B and 318
    Default 7 pin connector corroded?
    OK, on every trailer I've owned (two....) pins five and six (left and right turn signal) connector pins on the trailer ALWAYS get corroded, even though they don't get wet. What the heck?
    What are the chances the onboard trailer battery is causing some kind of galvanic action to cause the corrosian? As of now I'm disconnecting the 12V battery when the trailer is not in use, this problem comes up once a year....
    Is it just me or does anyone else run into this?
    Wayne
  2. #2
    Silver Member rkeith's Avatar
    Join Date
    Aug 2011
    Posts
    174
    Prattville, AL
    GC1720 TLB
    Default Re: 7 pin connector corroded?
    Probably moisture from the roadway. I used to have that problem but I solved it by using a conductive gel from Advanced Auto and put it on the trailer connection so when I plug it in it puts the gel right where it needs to be! It is conductive so I only put a dab on each of the 7 pins. Seems to work great!
    Robert
    GC1720 TLB
    Take-offs are optional but landings are mandatory!
    Blood goes round and round; air goes in and out. Any deviation of these two is a problem!
  3. #3
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Quote Originally Posted by Wayne_H View Post
    Wayne
    I always have the same problem. Less on the 7 ways, more so on 6 ways. Matter of fact I've converted all 10 of my trailers to 7 ways. A little dielectric grease helps, and what position your plug is stored in, I have found, makes a difference of how much rain gets into it.
    "It is better to be thought a fool, than to open your mouth and prove it."
  4. #4
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Put dielectric grease one then plugs and that will end you problems.
    You must clean them up first.
    Chris
  5. #5
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    3,015
    Kansas...USA
    Kubota B2620 , Case 448 , Kubota B2650
    This is my experience on a 6 (?) pin trailer. Even new it made poor connection. I figured it was corrosion and used a battery terminal wire brush to shine it up. But later I noticed that the connection would always work if the sag in the connection was lifted with a zip tie or cord to hold the line up. A hole in the bumper where the spare tire jack-rod was a handy to place to tie it "up". Cheers. Mike
    Kubota B2620 (2012) Case 448(1983) Kubota B2650 (2018)
  6. #6
    Gold Member
    Join Date
    Dec 2004
    Posts
    383
    Guys: I have tried the dielectric grease route, I really don't see much difference with that.
    But, these connectors have seven pins.... why is there corrosion only on the two pins used for the left and right signal (and brake lights)? That is some kind of clue, the metal does not turn green on its own (at least the other five pins don't...)
    Just fishing for ideas, I always keep it dry and it does not get moisture in the connector.
    regards
    Wayne
  7. #7
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,837
    Nova Scotia, Canada
    What do you use to protect from road spray and humidty in the air?
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  8. #8
    Veteran Member moored4's Avatar
    Join Date
    Jan 2011
    Posts
    2,368
    Great NorthWest /Southwest Washington
    Kubota l245dt, l3540, 8N
    Have you disconnected the plug and then checked it with a ohms meter to see if there is any stray current present? With everything shut off there should not be any current except on the positive battery supply line.
    "keep them pots black, shiny, and full of good Food and Fellowship!"
    Moore Cookie
  9. #9
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    i pack my connectors with grease unde rthe caps..
    soundguy
  10. #10
    Join Date
    Aug 2010
    Posts
    133
    Ontario
    John Deere 68, Honda H3011H
    regards
    Wayne
    My guess would be that those two circuits see the highest current and a much higher number of "on" and "off" cycles. If the contact pressure between the male and female terminals is not adequate, it would be just like switch contacts arcing. What I would do is thoroughly clean the terminals inside and out with steel wool and spread the male terminals a bit with a knife blade. This will increase the contact pressure. Then, coat the terminals with dielectric grease to make it easier to insert the plug with the spread terminals and also keep out moisture. What someone else said earlier about supporting the connector also makes sense, because that would reduce vibration "fretting" the terminals.
Similar Threads
  1. Ford 800 hard steering to left
    By george46 in forum Parts/Repairs
    Last Post: 05-31-2017, 11:15 AM
  2. ? on loose hitch pin
    By wilnis in forum Trailers & Transportation
    Last Post: 06-23-2010, 12:33 PM
  3. Backhoe Woods Backhoe Pin Problem - suggestions?
    By Jay4200 in forum Attachments
    Last Post: 10-19-2006, 03:58 PM
  4. Dump Truck snaped a pin!!
    By EddieWalker in forum Construction Equipment
    Last Post: 10-08-2006, 08:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
