Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Default Ramps vs. Tilt deck
    Looking for some experience with tilt deck trailers. I use my trailers just as much in the snow as in the summer. I really like the idea of not messing with ramps, but my concern with getting tilt deck trailers, is loading and unloading in snowy/icy conditions. Anyone have any experience with this?
    "It is better to be thought a fool, than to open your mouth and prove it."
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default Re: Ramps vs. Tilt deck
    I have used a tilt deck trailer and did not like it for me. When I had mud or wet tires it felt very unsafe. I also like loading other implements on the trailer first with the loader then put the tractor on. Very tough with a tilt deck.
    To me a tilt deck is for a guy with a classic car who only takes it out in good weather. Ramps are fool proof, not as much trouble as many think they are, and always work. They are also much lighter. A 18' tilt deck trailer can be as much as 500# heavier.
    Get a low boy trailer like mine with no dove tail and rear slide in ramps. My trailer is 18' long and only 14" deck height. With 5' ramps my angle is very low. I have no issue loading Corvettes if that gives you a idea. I can pull the pins and have the ramps in place in about 20 seconds each if I take my time and store the pins. Usually 30 seconds total for the ramps to come out or back in.
    Wood deck is also the only way to go for slippery situations. Never seen a tilt with a wood deck, only steel.
    Chris
  3. #3
    Platinum Member Iowachild's Avatar
    Join Date
    Feb 2006
    Posts
    982
    NW PA
    Kubota B2320HST
    Fold up ramps work well for me. BTW Chris a guy I work with has an 18' tilt with wood deck.
    Attached Thumbnails Attached Thumbnails Ramps vs. Tilt deck-dscn2457-jpg
    MIKE
    Ephesians 6:12
    America is a Constitutional Republic.......NOT a democracy! Our founder knew democracies never last!
    "Iowa Child" by Sarah Hall Manley
  4. #4
    Gold Member Bigkrank's Avatar
    Join Date
    Jan 2009
    Posts
    325
    NW Ohio
    I have an H&H equipment tilt bed trailer with a wood deck. I feel a winch is a necessity for loading along with remotes for the winch and the tilt if you work alone.
    They are a pain if you haul mostly multiple items as in if you need to load something (with wheels), tie it down and load something else.
    The main reason I went tilt deck was because I sometimes haul my scissors lift and forklift. They can be more of a pain for other things and dangerous if you work alone without the remotes.
    Picture loading a tractor with somewhat bad brakes. With a ramp trailer you drive up and go level and no issues. With a tilt deck you have to hold the tractor on the incline and lower the bed, hard to do without the right options or a helper you trust.
    Several garden tractor pullers
    Kubota B2630
    Kubota ZD1211
    Ford 655D backhoe
    Bobcat T190, various attachments
    Numerous Farmalls
  5. #5
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    I've had no issue with my ramp trailers. I'm going to upgrade to aluminum trailers, cuz of salt during snow season, and was considering tilt decks with a front stationary vs. ramps. You guys are confirming what my gut was telling me. Thanks for taking the time to help out a fellow TBN'r.
  6. #6
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,142
    Central Square, NY
    LS XR3037HC
    Like Bigkrank I also have an H&H car hauling tilt bed. Mine is a 20'er, 82" between the fenders, with power up and gravity down. I like it and have used it winter and summer. The tilt angle isn't that much, maybe 10-15 degrees. I have a winch as well. In winter I usually carry a small pail of cat litter to put on the deck if slippery but haven't had to use it since 2005 when I bought the trailer. I don't have a place to keep it inside so I have to shovel off the snow if I want to use it in winter. Mostly use for hauling the tractor but have hauled many cars and trucks as well.
  7. #7
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    I guess I though we were talking car hauler trailers, not equipment trailers. I have seen wood deck tilt equipment trailers.
    Chirs
  8. #8
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Quote Originally Posted by Diamondpilot View Post
    1*Very tough with a tilt deck.
    Quote Originally Posted by Bigkrank View Post
    2*They are a pain if you haul mostly multiple items as in if you need to load something (with wheels), tie it down and load something else.
    1* & 2*Add hyd tilt and a winch and ramps..
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  9. #9
    Join Date
    Jan 2009
    Posts
    325
    NW Ohio
    Quote Originally Posted by LBrown59 View Post
    ??? I have both already.
    Kubota B2630
    Kubota ZD1211
    Ford 655D backhoe
    Numerous Farmalls
  10. #10
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    953
    Gator Country
    New Holland TC40D HST 4WD FEL/BH
    Our 21' has a beaver tail and ramps. The nice thing is that the ramps are removable.
    I regularly use the trailer without the ramps for hauling recycled cardboard.
    It is fairly easy to put the ramps on to load the tractor.
    Here are a couple things I have found with the ramp trailer that I probably would not try with a tilt:
    I had the ramps off and needed to load the tractor. I was able to back the wheels in a depression and use the FEL to lift the tractor front and get the front wheels on then just drove the tractor on.
    When I went to unload, I just un-hitched the trailer from the truck and backed off. I let the front of the trailer go up and used the FEL to control the front of the trailer to the ground by pressing on the back and lowering it slowly.
    I did this instead of putting the ramps on because I needed the trailer the next day with the ramps off and didn't want to have to put them on/off.
    I will stick with the ramps for my equipment.
    New Holland Workmaster 45 2WD Gear
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
Similar Threads
  1. metal deck vs. wood deck
    By lizardman in forum Trailers & Transportation
    Last Post: 07-10-2011, 01:30 AM
  2. PT vs Composite Deck
    By MikePA in forum Related Topics
    Last Post: 05-21-2010, 01:31 PM
  3. Installing 60" mmm, badly in need of help-
    By teeravis1 in forum Kubota Owning/Operating
    Last Post: 05-28-2008, 07:19 PM
  4. Leveling 914A
    By SacandagaBrad in forum New Holland Owning/Operating
    Last Post: 10-08-2003, 07:33 AM
  5. Mowing New mower deck... Purchase sight unseen?
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 04-22-2003, 08:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
