Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Sep 2010
    Posts
    174
    Mississippi
    Kubota M9540 HD 4x4
    Default 95 F350 SRW 4x4 PSD
    Found a 1 owner clean crew cab with 144,000 miles for $6,700.00. Don't know much else. I rreally like the 7.3 over all the new diesels. Is it worth it? It looks cleaner and nicer and has less miles than my 2000 F150. Just thinking about belts, hoses, injectors, glow plugs and other costly up keep on a truck this old.
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I am not real familiar with the 7.3 Is it truly a PS or is it a old non turbo 7.3?
    Chris
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 95 F350 SRW 4x4 PSD
    check out undercarriage for rust from salt.. etc.., wear parts like brakes.. all the electrical work? etc.. etc.
    soundguy
  4. #4
    Join Date
    Jan 2011
    Posts
    573
    Richmond, IN
    Kubota MX5100
    If it's a '95 7.3 then it's a Power Stroke. Good trucks! Keep a spare cam sensor.
    Kubota MX5100
    '95 Ram 2500 CTD
    Stihl MS441 ported
    Stihl MS280 ported
  5. #5
    Join Date
    Jun 2006
    Posts
    193
    I had a 1995 F350 crew cab 4x4 PSD 5spd. I really liked the truck, but the last 40k miles I owned it, the repairs ended up being equal to the payment on a new truck, so I traded it and bought new. Everything up to 200k miles was pretty basic maintenance, it was 200-240k that got me.
    I agree with the comment about a spare CPS in the glovebox, and keep a 6pt 10mm wrench in there too.
    Glow plugs, glow plug wiring harness ( it is built into the valve cover gasket), glow plug relay (Napa GPR109 if I recall correctly) are all pretty common issues, none of which are very expensive.
    If it has a 5spd, the factory dual mass flywheel is a poor design, you will end up upgrading to a LUK 13" clutch assembly.
  6. #6
    Join Date
    Jun 2006
    Posts
    193
    Quote Originally Posted by Diamondpilot View Post
    Chris
    1993 Ford offered a 7.3 idi non turbo and a 7.3 idi turbo (ATS turbo I believe)
    1994 Ford offered a 7.3 idi non turbo, 7.3 idi turbo (automatic only) and a 7.3 di turbo aka Powerstroke, (5 spd manual only)
    1995 Ford only offered the 7.3 di turbo / PSD in both auto and stick
    1999my ( actually 1998 ) Ford introduced the Superduty
    2003 Ford offered both 7.3 di and 6.0
    There are only a few split years in the ford diesel history. I think 1987 was one also, changing from the 6.9 to the 7.3
  7. #7
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    Quote Originally Posted by CCOUGHRAN1 View Post
    yep.. my center console has a 10mm wrench and the cps box.. with wrench taped to the box..
  8. #8
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    For almost $7k, you should be able to get the newer body style (99+) diesel. I had a 94 non-turbo diesel that was pretty weak and the E4OD 4-speed auto in those trucks was a constant problem as well.
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  9. #9
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    I doubt he will get a 99+ 4wd and crew cab 7.3psd for 7k$, in the milage range he wants.
    I looked for months to find my DRW version of that machine. lots of 10-15K trucks I looked at.. and most of those were hosed. found a couple cheaper that needed work.. etc.. so.. still about 10k.. etc..
    soundguy
  10. #10
    Veteran Member RDrancher's Avatar
    Join Date
    Aug 2011
    Posts
    2,180
    North Texas
    New Holland TC35D, Kubota SVL90-2 CTL
    That's an fair price for the mileage. I love that body style. The 7.3 in my early '99 continues to amaze me. It just turned over 268,000 this evening. The auto trans...not so much (I'm on my 4th rebuild).
    John
    My Work & Stuff Photo Thread: http://www.tractorbynet.com/forums/p...to-thread.html
    John 14:6
Similar Threads
  1. Anybody here have any experience w/ Ford SD 6.0 PSD?
    By Dargo in forum Trailers & Transportation
    Last Post: 07-28-2014, 04:38 PM
  2. '03 Ford F350 6.0 PSD Issues
    By jayste in forum Trailers & Transportation
    Last Post: 04-11-2011, 01:26 PM
  3. 2006 F350 Lariet Crew Cab SRW
    By MikePA in forum Trailers & Transportation
    Last Post: 03-29-2010, 08:40 PM
  4. 99 F350 4X4 engagement
    By AlanB in forum Trailers & Transportation
    Last Post: 03-16-2008, 09:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
