Results 1 to 10 of 10
  1. #1
    Veteran Member sparc's Avatar
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
    Default Vehicle Curb Weight
    I realize the curb weight of any vehicle will vary with the selected options but why is the 'as built' curb weight of a vehicle not included on the sticker along with the front and rear axle max weight ratings, tire information, etc.
    Is it because they are worried that people will use that number and not calculate the actual weight of the vehicle at the time they go to put that heavy load in the truck bed or connect a trailer? I could see people doing just that and then not allowing for a couple hundred pounds of junk stowed in the bed box or the four people in the cabin and then being overloaded.
    But just the same it would be nice to know the weight of the vehicle as it was built and delivered to the dealer and owner.
    Yes, I can run it across a scale but it seems like something that is easily known at the time the vehicle is built.
    I've looked through much literature on the Ford website and not found this information posted anywhere.
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    I have wondered the same. In the mean time I weigh them with me and 3/4 tank.
    Chris
  3. #3
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    7,989
    Central Square, NY
    LS XR3037HC
    Default Re: Vehicle Curb Weight
    I did a search for Ford truck curb weight and found several sites that list the curb weight (or base weight). This is a general guide and curb weights may not be listed because that weight will vary slightly depending on the options on each truck (see attached explanation).
    What engine, sunroof, alum. or steel wheels, transmission, cd player, even floor mats each item makes a difference in curb weight.
    I guess the best way is to weight your truck on a scale. The GVWR sticker is what's really important.
    Attached Files Attached Files
  4. #4
    Veteran Member jwstewar's Avatar
    Join Date
    Sep 2001
    Posts
    2,458
    South Central Ohio
    2003 New Holland TC24D
    That is something I really like that Jayco did with our camper. On the website they list the base weight of the trailer. When you actually get the camper there are stickers on the inside of the door and inside the cabinets. They list what the trailer is rated to haul (9800), what it weight from the factory with battery and full propane tanks (7984), what a load of fresh water weights (384), and how much the cargo should never exceed (1814). Still doesn't give you a true tongue weight and it doesn't tell me how much all of our crap weighs, but it gives us a good starting point until we can get it to the scales.
    Jim
    New Holland TC24D
  5. #5
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,037
    Central Ohio
    Kubota MX5100
    All the ones I have seen DO include the axle weight ratings, front AND rear.
    But I too would like to see them include the curb weight.
    Not just for trucks, but cars also Shure would make it a whole lot easier come scrapping time for our field cars
    But like D-pilot, I weigh mine as well.
    My 2003 chevy 1/2 ton 4x4 ex cab short bed with me + fuel + toolbox scaled @ 5900lbs.
    My 2005 Dodge 4x4 DRW quad cab LB with me, fuel, and handfull of junk, and plow mount less pump was ~8000lbs
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #6
    Silver Member wolfpack2's Avatar
    Join Date
    Dec 2004
    Posts
    238
    SE Michigan
    JD 4520
    As of Sept 2003, all new vehicles under 10,000 lb GVWR are required to have a payload label that states the maximum allowable payload. If you subtract the payload from the GVWR, you will get the approximate curb weight of the vehicle.
    Attached Thumbnails Attached Thumbnails Vehicle Curb Weight-fig1-gif
  7. #7
    Join Date
    Oct 2011
    Posts
    1,086
    NJ
    Quote Originally Posted by wolfpack2 View Post
    I had thought that too after I made my original post. It would get you in the ball park and close enough for most purposes.
    Q: Did you post the right example label? That is a tire rating label which gives the correct tire size and pressure for the tires on the vehicle. I did not see axle ratings or GVWR on there.
    Thanks everyone for your comments. Jumping on the scale is the best and I will do that when my new truck arrives...hopefully before Christmas.
  8. #8
    Elite Member Duffster's Avatar
    Join Date
    Mar 2009
    Posts
    4,372
    Wisconsin
    Quote Originally Posted by sparc View Post
    Those numbers are all on the vin tag.
    "If everyone is thinking alike, someone isn't thinking." George Patton
  9. #9
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,200
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    It says on there "The combined weight of the occupants and cargo should never exceed xxxx kg or xxxx lbs" (just below the tire logo)
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  10. #10
    Join Date
    Feb 2008
    Posts
    224
    Ford body service web has a options weight website that may be of interesthttp://https://www.fleet.ford.com/tr...Payload_SB.pdf.
    GM has a weights calculator that configures options and package into a payloads and axle loads. http://http://eogld.ecomm.gm.com/NAS...1&divisionID=1
    The trucks FAWR/RAWR and GVWR are on the trucks certification placard on the drivers side door post. Those never change with factory/owner added equipment.
    Maybe some one can make athem a clicky if their not working. Thanks
Similar Threads
  1. Pickups and Legal Trailer Weight Limits
    By Dk45_Jeff in forum Trailers & Transportation
    Last Post: 05-04-2015, 11:30 PM
  2. Too much Weight in the Weight Box?
    By captplaid in forum John Deere Lawn & Garden
    Last Post: 12-23-2010, 04:05 PM
  3. Did I purchase the right trailer?
    By SamWalton in forum Trailers & Transportation
    Last Post: 12-26-2008, 07:36 PM
  4. TC55 Steering Problems Fixed?
    By mundamanu in forum New Holland Buying/Pricing
    Last Post: 10-25-2006, 09:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
