Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Bronze Member Rhon's Avatar
    Join Date
    Mar 2011
    Posts
    86
    Maple Valley Washington
    New Holland TC18
    Default pickup to flat bed
    So I'm thinking of pulling the box off my truck and replacing it with a flatbed. It's been in the back of my head for years. I don't haul anything in the box other than hay, lumber, stove pellets and it would be easier to stack hay on the flat bed than in the box.
    Has anyone else done it? Pros...cons...
  2. #2
    Gold Member
    Join Date
    Jun 2009
    Posts
    274
    Sumner county, TN
    Default Re: pickup to flat bed
    I love my flatbed. There's a lot more space, and it's easier to properly strap things down. The downside is, pretty much everything has to be strapped down unless you build some sides that drop down into the stake pockets.
    You can side load with a forklift. In a regular pickup, you might fit two pallets in if you take the tailgate off, and use one pallet to push the other all the way to the front of the bed. Good luck getting that front one out, too. I can fit 4 on a 9' long flatbed, and 6 on a 12'. Each one is easily forklift accessible, too. What you want to do sounds ideal for a flatbed.
    I'd recommend you get rub/ strap rails down the sides, not just strap to the sides. Most pickup sized beds are 96" wide, and the extra couple of inches the rails stick out make it much easier to hook straps if you're loading pallets on it. Be sure when you start looking for beds you make sure to find ones made for a truck with a pickup bed. 'Regular' beds are designed for chassis cab trucks, and the frames are a little bit different. Neither one is really better, but it is something to be aware of when you're shopping.
  3. #3
    Join Date
    Jan 2005
    Posts
    74
    Waterport NY
    Quote Originally Posted by Rhon View Post
    Once you have a flatbed you wont ever want a pickup box again!! You can haul so much more with a flatbed than a regular pickup box.Easy to work off 3 sides of it if you put removable side boards on..Depending on your location for winters I would recommend a 2x6 deck boards with a full rub rail on all 3 exposed sides so you have plenty of tie down space and a way to keep things inside the bed.. My next flatbed for my pickup is going to be 7 foot wide by 8 foot long with 6 feet of lumber with a 2 foot wide steel deck on the back of it to work off of.
  4. #4
    Gold Member
    Join Date
    Sep 2011
    Posts
    340
    Corpus Christi. Tx
    Case 485
    I am a flatbed fan, I think the main draw back is having to tie down the small stuff that you can throw in a truck bed. On the other hand properly secured items on a flatbed wont fly out of the bed.
    Flatbeds offer more load versatility, you can also hang the tool boxs/aux. fuels tanks under the bed, keeping the full bed space for loads. To me its easier to add accessories like removeable racks, vices, winch and pole setups to flatbeds. Another thing is its easy to touch up the paint if you go with the standard black bed
  5. #5
    Gold Member hrcarver's Avatar
    Join Date
    Apr 2010
    Posts
    446
    NC
    jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
    I know the next truck I buy will be a flatbed srw. Not sure what it takes to convert one. I know the chassis are setup different on pickups.
    http://www.bioplots.com/
    Food plot seed, services, and mineral supplements
  6. #6
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,402
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    I thought about doing that on my 2001 F150, but then I found a good deal on a 2004 Isuzu NPR/EFI stakebed (8x14 ft bed, 49500 miles, 6L GMC LQ4 V-8 gasser, $11K on eBay). You're right--it's a lot easier to load than a pickup. I bought about 800 lb of seed a few weeks ago---palleted and fork-lifted by the seed guys onto the stakebed, no muss, no fuss.
    pickup to flat bed-dscf0006-small-jpgpickup to flat bed-dscf0007-small-jpg
    Good luck.
  7. #7
    Gold Member
    Join Date
    Jun 2010
    Posts
    329
    North west NC mountains
    BCS 850
    Pro's- It's flat. With stakes/standards you can haul a lot. Easy to make a dump bed. some loads are easier to strap down if you have tie down points. No fenders to bang up
    Cons: May be harder to climb up on. The bed will be higher. Think about trailer hitch, especially if you use a gooseneck. May be wider than the truck body, something else to catch on that gate post Stuff won't stay in the bed unless restrained. Tool boxes can either be easier to use(under bed) or harder to get to,
    If you have duals, width of the bed is not much of an issue, wide is ok. If you have SRW, then a wide bed looks like an add-on, not "normal" what ever that is
    A little more rust on mine, it might end up a flatbed too
  8. #8
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Also check with your insurance man. A flat bed will change things with some companies.
    I have had both and went back to a Pickup Box. The cons were just too much for me and if I need to haul that kind of stuff I just use my trailers.
    Chris
  9. #9
    Veteran Member powerstroke444e's Avatar
    Join Date
    Jan 2008
    Posts
    1,224
    Near Springfield IL
    mostly orange
    Default
    For a work truck flat bed is only way to go, but with a hoist they are priceless.
    Here's a picture of one I built. There's a tread on it some were on here.
    Attached Thumbnails Attached Thumbnails pickup to flat bed-forumrunner_20111221_205009-png
    If it ain't smokin' it's broken.
  10. #10
    Join Date
    Mar 2011
    Posts
    86
    New Holland TC18
    Lots of great comments. I didn't think about the difference between a pick up and a chassis frame. I'd be converting a srw 96 F250 4x4. All of my trailers are bumper pull but I'd make sure it came with a turnover ball. It just seems more practical for me. The biggest hurdle won't be doing it but convincing the wife/boss...
    Thanks guys
Similar Threads
  1. Off Road Flat Bed Trailer for ATV/UTV?
    By Hotwheels in forum Trailers & Transportation
    Last Post: 03-27-2015, 04:46 AM
  2. Putting a pick-up bed on my F-550
    By MrJimi in forum Build-It Yourself
    Last Post: 09-11-2012, 06:29 PM
  3. Can you haul a full size Trans mule in a 8" bed pickup?
    By JL Sargent in forum ATVs & Utility Vehicles
    Last Post: 10-26-2011, 12:34 PM
  4. TSC Carry All / added wood hauler / flat bed
    By maxfior in forum Build-It Yourself
    Last Post: 02-01-2011, 12:44 PM
  5. Ohio Steel Flat Bed Dump Cart for BX
    By derecskey in forum Kubota Owning/Operating
    Last Post: 07-01-2008, 02:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
