Results 21 to 30 of 57
01-02-2012, 07:23 PM #21Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,452
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Re: Vexing towing problem
I would have a dozer or large farm tractor pull you and your truck up. Dont try two trucks, that is a disaster waiting to happen.
Chris
01-02-2012, 08:01 PM #22Super Member
- Join Date
- Apr 2000
- Posts
- 7,582
- Location
- Shingle Springs California
- Tractor
- New Holland TC40D
With the 5th wheel, if you can get it up there, then you may need to manuever, disconnect and reposition the angle of the truck, reconnect. Repeat as necessary.
Someone else mentioned about clearance. Make sure as you start up and hill, and you crest it, that you don't hit the top of the bed with the trailer.
I have a short section of steep drive with a curve; I have to watch how I approach that area. Starting up the hill, the front of the 5th wheel gets close to the bed. As I crest the hill, the top of the taligate gets real close to the trailer body. Never actually bumped, but I do approach that part of the drive carefully.
RobertN in Shingle Springs Calif
01-03-2012, 08:33 AM #23Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
i think i'd have the dozer pull me up.. or / and fix that steep drive. you will be driving it EVERY day...
soundguy
01-03-2012, 08:56 AM #24
01-03-2012, 09:00 AM #25Super Member
- Join Date
- Jun 2005
- Posts
- 5,679
- Location
- Northern California-Tehama Co.
- Tractor
- 2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
Suppose: big dozer not available, big ag tractor not available.
But: friend has a 3/4 or 1T pickup with a front mounted winch.
Now solve the problem.
01-03-2012, 09:06 AM #26
If you can make sure the video cam is rolling when you make this happen
01-03-2012, 10:42 AM #27Super Member
- Join Date
- Feb 2008
- Posts
- 7,733
- Location
- somewhere usa
- Tractor
- stuff
I would grade the driveway first whether you concrete it now or wait. I would then get the above mentioned mobile home tracked mover to put your trailer in place. this would be the least costly way to do it. I should also mention the mobile home guys are insured to do this type of work in most cases, and they are the experts at this type of moving and positioning too.
Haven't seen any pics of this but grading the area ahead of time will give you a chance to let it pack down with the heavy trucks and get a better idea of how well it will work longterm. Better to know before you pour.
01-03-2012, 11:36 AM #28Super Member
- Join Date
- Apr 2000
- Posts
- 7,582
- Location
- Tractor
- New Holland TC40D
01-03-2012, 11:50 AM #29Veteran Member
- Join Date
- Nov 2010
- Posts
- 1,304
- Location
- Buckner MO
- Tractor
- 2005 Kubota L5030 GST; Farmall 706
beckmurph mentioned a mobile home mover....I want to agree with her, but I don't know if they can hook onto a fifth wheel or not. IF they can, this would be the ticket:
Dean
01-03-2012, 07:06 PM #30New Member
- Join Date
- Jan 2012
- Posts
- 2
- Tractor
- Universal 640 DTC
Similar Threads
B2400 starting problem finally solved
By victor43 in forum Kubota Owning/OperatingReplies: 39Last Post: 05-04-2013, 12:30 AM -
Boomer Problems
By froggy in forum New Holland Owning/OperatingReplies: 19Last Post: 04-26-2013, 09:22 PM -
Power Steering Problem Not Solved
By Alan L. in forum Kubota Owning/OperatingReplies: 87Last Post: 03-31-2011, 06:35 PM -
Starting and Stopping Problem kubota F2100
By ebertf in forum Kubota Owning/OperatingReplies: 2Last Post: 05-05-2008, 12:04 PM -
New BX 2200 Throttle Problem
By Anonymous Poster in forum Kubota Owning/OperatingReplies: 3Last Post: 06-02-2003, 10:23 PM
