Results 21 to 30 of 50
01-21-2012, 10:09 AM #21
Re: Can you "up-rate" a new trailer from 9,990# to 14k#?
You can go but we will stay and argue more
I know we've had this crazy 10K trailer - 26K CGVW discussion before,
But I can't remember, do you go by the tag ratings or the actual weights.
Like with your brother's 13K truck and 14K trailer. If his actual weight was under 26,000K would that be legal???
JBJD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
01-21-2012, 11:33 AM #22
I am still here, but the trailer decision has been made by my brother.
His understanding from the authorities is that the 26k question is about ratings, not what you are carrying.Kubota BX2230, FEL, Woods BH, 60" MMM, Bagger, 4' Box Blade, PHD, 8' x 20' 10k# Dovetail Trailer
Those of you who think you know it all are particularly annoying to those of us who do.
01-21-2012, 12:50 PM #23Gold Member
- Join Date
- Mar 2008
- Posts
- 280
We have property in NC too, so that's why I tried to read up on this stuff before moving there.
I know you're saying the manual is wrong but even if it is I don't think it makes a difference. You should read ALL of the statute that pertains. The section of the statutes you're quoting (20-4.01) is only the definitions preamble, and it's only defining types of vehicles, not types of licenses.
If you read down a little further to 20-7, that is where they describe the actual classes of non-CDL licenses and what you're allowed to drive with them.
So there you have it, it is spelling it out exactly the way I interpreted it from the manual. Even with just a Class C license you can drive non-commercial combinations between 10K and 26K as long as not under 18 years of age.20‑79(a) The classes of regular drivers licenses and the motor vehicles that can be driven with each class of license are:
(1) Class A. A Class A license authorizes the holder to drive any of the following:
a. A Class A motor vehicle that is exempt under G.S. 20‑37.16 from the commercial drivers license requirements.
b. A Class A motor vehicle that has a combined GVWR of less than 26,001 pounds and includes as part of the combination a towed unit that has a GVWR of at least 10,001 pounds.
(2) Class B. A Class B license authorizes the holder to drive any Class B motor vehicle that is exempt under G.S. 20‑37.16 from the commercial drivers license requirements.
(3) Class C. A Class C license authorizes the holder to drive any of the following:
a. A Class C motor vehicle that is not a commercial motor vehicle.
b. When operated by a volunteer member of a fire department, a rescue squad, or an emergency medical service (EMS) in the performance of duty, a Class A or Class B fire‑fighting, rescue, or EMS motor vehicle or a combination of these vehicles.
c. A combination of noncommercial motor vehicles that have a GVWR of more than 10,000 pounds but less than 26,001 pounds. This sub‑subdivision does not apply to a Class C license holder less than 18 years of age.
As far as the original poster and his brother goes, yes he would need a CDL if the truck was 13K and the trailer was 14K, unless he was a farmer staying within 150 miles.
01-21-2012, 12:54 PM #24Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,459
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Around here the go by the ratings, not actual weight.
They also look at the data plate, not the axles as was stated by the op.
Chris
01-21-2012, 01:02 PM #25
Thanks for replying. Finding out what is or is not possible on re-rating a trailer in CT is tough for whatever reason. I think I'm going to stop by a few trailer repair/sales places to see what they can tell me. Maybe if I have them do the brakes, they can get it re-rated for me. If not, I can do them myself but I don't want to put a lot of money into a trailer that can't be rated for what it's capable of.
Chris
2 acres and a mule, er, Kubota BX25, and too many other toys,er, tools to list.
01-21-2012, 01:02 PM #26
There was some mixed input on that from the authorities on this issue, but the state police person my bother spoke to was the one that said he'd be suspect of the de-rated GVWR if he pulled my brother over. I guess it depends on what side of the bed he woke up on.
Let's be honest. If you have a trailer that is built like a brick poo-house, CLEARLY has 7k# axles, has the individual axle ratings of 7k# listed on the data plate, then has a GVWR of 9,990#, then anyone with a brain will know something is up.
If my brother doesn't get bitten by one thing (being good to 26k# by having a de-rated trailer), he'll be bitten by another thing: Overloading his trailer.
The Kubota MX5100 with loader and 9.5 foot backhoe is no joke. It will fill a trailer. If the officer-in-question thinks about it too hard, he'll realize that there is NO WAY the trailer weighs less than 4k# and there is NO WAY the tractor weighs less than 6k#. Put 2-and-2 together, and there's a problem.
There is an easy way to side-step the problem: Buy the correct trailer for the situation.Kubota BX2230, FEL, Woods BH, 60" MMM, Bagger, 4' Box Blade, PHD, 8' x 20' 10k# Dovetail Trailer
01-21-2012, 01:08 PM #27
If you have a 14K trailer rated at 9990 GVW and only haul up to 9990 GVW then I would assume there is nothing they can do about it.
01-21-2012, 03:10 PM #28
01-21-2012, 03:16 PM #29
i still would re-issue trailer as homemade. Also, keep in mind the rating on the trailer is different than registered weight. i could put 16,000lbs of registration on a two axle trailer, that is "stamped" as a 12,000lb trailer. The "law" might pick up on this if you're stopped. Maybe not.
TN75D, w/cab, FEL, BH
7 1/2 ft Lucknow Blower
01-21-2012, 03:34 PM #30
Would be curious what the coupler is rated at, don't forget everything has to be rated, tires, springs, wheels, even the U-bolts and shackles. of course that means the frame.
I know I went through this with my trailer, it obviously has two 5200 axles but the rest is built like a 8K trailer. though they call it 9K cause they are factoring in the tongue weight
I have no idea why, they would do that.
Similar Threads
Michelin XPS RIB LT235/85R16E on a 14K trailer
By bluehog in forum Trailers & TransportationReplies: 10Last Post: 11-02-2011, 08:52 PM -
Built my own trailer / Introduction
By MGAREL in forum Trailers & TransportationReplies: 8Last Post: 10-15-2011, 09:01 PM -
Trailer Thefts in Tarrant and Parker Co. Texas
By two_bit_score in forum Rural LivingReplies: 1Last Post: 09-01-2009, 08:47 AM -
Trailer Troubles / Decisions
By Yooper3830 in forum Trailers & TransportationReplies: 52Last Post: 08-10-2005, 09:16 PM -
B7500 & Single axle trailer
By BILLMAN in forum Trailers & TransportationReplies: 50Last Post: 11-09-2001, 05:01 PM
