Page 5 of 5 FirstFirst ... 2345
Results 41 to 50 of 50
  1. #41
    Silver Member Sterff's Avatar
    Join Date
    Dec 2011
    Posts
    183
    Default Re: Can you "up-rate" a new trailer from 9,990# to 14k#?
    Here is the chart for the registration fees. If your trailer is over 10K it needs to be combined. So since my truck is 8800 GVW and the trailer is 14000 GVW I would need a class 8 registration sticker for my truck (21,001-26000 GVW). In PA big rigs have the class 25 sticker. I think the whole thing is confusing...
    Attached Thumbnails Attached Thumbnails Can you "up-rate" a new trailer from 9,990# to 14k#?-registration-rate.jpg
  2. #42
    Super Member JB4310's Avatar
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Quote Originally Posted by Sterff View Post
    I would say you could get away with it until you get pulled over by DOT. Then when they weigh you, you better hope it's not over 9990 GVW or you will get fined I'd imagine. The only reason I want to set mine to 9990 is to avoid combination plates.
    In PA it would cost me $405 a year in registration plus Id have to inspect the trailer twice a year (additional $100).
    Do they always look at the trailers reg? mechanically you would be safe.
    I agree with saving money on the plates, my dump and flatbed are registered as camp trailers, which is what they give you if you are not using for commercial, huge difference in reg cost.
    JB
    JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 48", 61"HD & 73" high volume bucket.
    FORD 1700; 2 WD, 2600 hrs.
    JD 320; Hydra lift, 48" deck and 48" snow blade.
    2007 Dodge Ram 3500, Cummins 6.7L, Aisin 6 speed, 9ft utility body.
  3. #43
    Join Date
    Dec 2011
    Posts
    183
    Quote Originally Posted by JB4310 View Post
    JB
    Im not sure. If you are hauling safely and not hauling anything ridiculous Id say you will be fine. My old trailer which is registered at 9990 and is a 14K, I have hauled skid loaders, lifts, mini hoes, etc. and have not been pulled over.
  4. #44
    Gold Member
    Join Date
    Apr 2009
    Posts
    496
    Western Wyoming
    I don't think an officer or the DOT can issue tickets based on the axle rating. My snow machine trailer has a 3500 lb axle, but the rest of the tailed isn't built heavy enough. Just because the axles are 14k, doesn't mean the rest is built for 14k, therefore giving you a valid arguing point in court. I think they could only go by the tag. Maybe I read wrong, but they go by gcvw, or gross combined vehicle weight. Therefore if truck, trailer, and payload are under 26,001 lbs, they cannot do anything, if everything is rated for the amount of weight that is loaded. Maybe I need to go back and re-read...
  5. #45
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by tcartwri View Post
    This would be the proper way to do it. Just pulling the tag off of it and declaring it a home built is asking for trouble.
    but not defacto illegal.. at least in florida... remember.. every state is different.
    In fl.. if you can't produce a COO.. you go the homebuilt route, weight it, and tag it .
    soundguy
  6. #46
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,492
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Glad again I live in Indiana...
    Chris
  7. #47
    Platinum Member flyingcow's Avatar
    Join Date
    Jan 2010
    Posts
    974
    aroostook county maine
    in Maine--$14 for a trailer reg. No matter what the rating. $14 for my utility trailer. $14 for my 48ft milk trailer that i gross 100,000 lbs of weight. Nobody asks for a GVWR on trailers. But when you register power unit you pay the dollars for more weight.
    TN75D, w/cab, FEL, BH
    7 1/2 ft Lucknow Blower
  8. #48
    Silver Member ditzel's Avatar
    Join Date
    Mar 2007
    Posts
    147
    N.J.
    Mahindra 2615 Gear
    Quote Originally Posted by flyingcow View Post
    I do notice a lot of semi trailers with Maine tags on them around here in N.J., now I know why.
    _____________________________________________
    Mahindra 2615gear,Homemade QA,Pallet Forks,Rear Pallet Forks, WoodsBH,Boxblade,Yorkrake,Rearblade
  9. #49
    Join Date
    Aug 2011
    Posts
    125
    Theresa(Milwaukee) WI
    ford 800
    Would be curious what the coupler is rated at, don't forget everything has to be rated, tires, springs, wheels, even the U-bolts and shackles. of course that means the frame.
    JB
    I never figured out the whole coupler rating thing. I have a couple of trailers, and the two that I bought factory made have 5000# 2" couplers on them. The one is fine, as it has 1 3500# axle and no brakes. The other one, 16' however, has 2 3500#axles with brakes on both, double 4"x4"x1/4" angle for the frame, and is rated at 7000#. Seems to be missing 2000# somewhere in their math somewhere.
    I built a 20' hydraulic tilt bed trailer with 2 5000# brake axles, Double 4"X3/8" c-channel, and a 10,000# 2-5/16 coupler-see it all adds up
    "I WANT IT NOW, I WANT IT ALL" My 4 year old neice, and the OWS crowd.
  10. #50
    Join Date
    Feb 2005
    Posts
    5,645
    Central CT
    J.D. 4310 E-hydro
    Quote Originally Posted by me0418840987 View Post
    I agree, but not sure.
    JB
Similar Threads
  1. Michelin XPS RIB LT235/85R16E on a 14K trailer
    By bluehog in forum Trailers & Transportation
    Last Post: 11-02-2011, 08:52 PM
  2. Built my own trailer / Introduction
    By MGAREL in forum Trailers & Transportation
    Last Post: 10-15-2011, 09:01 PM
  3. Trailer Thefts in Tarrant and Parker Co. Texas
    By two_bit_score in forum Rural Living
    Last Post: 09-01-2009, 08:47 AM
  4. Trailer Troubles / Decisions
    By Yooper3830 in forum Trailers & Transportation
    Last Post: 08-10-2005, 09:16 PM
  5. B7500 & Single axle trailer
    By BILLMAN in forum Trailers & Transportation
    Last Post: 11-09-2001, 05:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
