Results 1 to 10 of 10
  1. #1
    Reg
    Reg is offline
    Elite Member
    Join Date
    Nov 2005
    Posts
    2,835
    Default Weight distribution ACROSS the trailer.
    This has probably been addressed before, but I'm probably not the only one to have noticed that trailers used for hauling tractors often get a couple of the boards really beaten up, resulting in sag.
    OK, leaving aside "you get what you pay for" and "quality ain't what it used to was"...
    Do any of you place, say a 2x12 across the trailer under the rear wheels to distribute the point load across a few more boards ?
    I can't believe that everyone is fortunate enough to have a substantial steel cross member right under where their tractor's rear axle is, though doubtless some do.
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,469
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Never had too and I have moved about everything with wheels. I could see having to do it with a piece of junk trailer.
    Chris
  3. #3
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,684
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Default Re: Weight distribution ACROSS the trailer.
    Quote Originally Posted by Reg View Post
    I did something similar to spread the load on my 2004 Isuzu NPR/EFI 8x14 ft stakebed using a few sheets of 3/4" thick plywood and some deck screws.
    Weight distribution ACROSS the trailer.-isuzu-plywood-1-small-.jpgWeight distribution ACROSS the trailer.-isuzu-plywood-2-small-.jpg
    The NPR is for hauling my small parade tractors (about 3500 lb max).
  4. #4
    Veteran Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    1,279
    central Iowa
    JD 2720
    I place a 2x5 piece of plywood under my tiller but that is just to keep from denting the aluminum floor on my Aluma trailer.
    HAVE FUN
    do yourself a favor, floss
    2720
  5. #5
    Gold Member
    Join Date
    Sep 2011
    Posts
    309
    Corpus Christi. Tx
    Case 485
    Sure, its done everyday on all kids of flatbeds, just look the 18 wheeler flatbeds going down the highway, they will have stripping under most loads.Granted it helps when loading/unloading with forklifts too, also helps on weight distribution across the deck of the trailer.For say like hauling a 40,000 lb reel of wire rope, has a foot print less than a foot wide and 2-3' long, no trailer deck would stand up to that very long.
    I do use stripping(4x4's,2x12'-depending on the load) all the time on my personal use bumper pulls, saves stress on the trailer and its safer for a load thats has alot of weight concentrated in a small foot print. Granted you have to consider your crossmembers strength and location,load location etc. I have never done this for my tractor, dont need to for my trailer/tractor combo I have now. I would if the situation warranted.
  6. #6
    Elite Member
    Join Date
    Sep 2003
    Posts
    3,946
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455
    Shouldn't need to for a tractor unless you have very lightly constructed trailer. The boards are there to spread to a couple of cross members already.
  7. #7
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,628
    Nova Scotia, Canada
    The Boards are not placed across the trailer. They go length wise. A set for each side. They are supposed to add a little support and also protect main deck from damage.
    It's a very common practice.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  8. #8
    Reg
    Reg is offline
    Elite Member
    Join Date
    Nov 2005
    Posts
    2,835
    Quote Originally Posted by slowzuki View Post
    Yes, they do that ALONG the trailer, but wheeled vehicles represent 4 point loads and the back end of even a small tractor with a hoe on it and loaded tires puts a couple or three tons on very few boards.
    Worst case may be 2 boards per rear tire, so spreading it to a few more just makes a bit of sense.
    My little trailer can take what I put on it, but I have seen trailers with noticeable sag in the boards at just about the place where the rear wheels go.
    How much of that is due to improper use is open to speculation,
    I would EXPECT some sag if a tractor were left on the trailer for several months with alternate rain and dry cycles.
    Wood DOES take on semi permanent bend if kept under enough force for long enough, especially when wet/dry cycles are involved.
    I have no doubt that SOME folk leave a tractor on a trailer for long periods of time, so much easier to not unload it if we're going back next week-end (-:
    Then something else crops up and next week-end becomes next month.
    I'm not saying this is NECESSARY for the occasional 2 mile trip across town, but it may be desirable with loaded Ag tires (narrowest) and a hoe.
    Especially if it is a tractor that gets hauled back and forth regularly and is left on the trailer for more than a day.
  9. #9
    Member
    Join Date
    Feb 2012
    Posts
    26
    USA
    I love my country living.
  10. #10
    Platinum Member crashz's Avatar
    Join Date
    May 2005
    Posts
    943
    Eastern MA & Upstate NY
    John Deere 770, Bobcat 753
    When I used to haul my father's roller (7500lb, double drum articulated vibartory Cat) to sites, I noticed that the inner 3 planks would bend slightly once loaded on our small equipment trailer. The perfect load position was with the drums placed right between cross members. Nobody else ever seemed concerned, but I would place 4'x6' sheets of plywood under the drums as a precaution. I never measured a difference in bending, but it seemed to help. The plywood would also make loading and unloading easier on the ramps.
    BTW - I replaced the decking twice on that trailer, and it would happen that same with new or aged decking. I think its due for it again.
    “I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
Similar Threads
  1. Horse trailer ?
    By ChrsDrn in forum Trailers & Transportation
    Last Post: 01-15-2010, 08:53 PM
  2. Need help with weight distribution of my equipment (PICS)
    By dieselfuelonly in forum Trailers & Transportation
    Last Post: 02-18-2009, 02:57 PM
  3. TRAILER WEIGHT
    By bjess8 in forum Trailers & Transportation
    Last Post: 09-26-2008, 09:18 AM
  4. Trailer Weight Distribution Question
    By EastTnFarmboy in forum Trailers & Transportation
    Last Post: 11-28-2007, 01:33 PM
  5. Weight distribution hitch
    By JoeR in forum Trailers & Transportation
    Last Post: 08-02-2006, 01:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
