Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    Platinum Member Red Horse's Avatar
    Join Date
    Dec 2010
    Posts
    553
    Bolton, MA
    Deere 655ZTrak, Deere 4720 Cab, 400 X
    Default LED Lights
    Guys, I put a new Galion dump body on my '56 B61X. The truck is 12V. I want to replace the two rear tail/stop lights and the two rear turn signals with two new LED combo stop/tail/turn lights.
    some say there is an issue mixing LED's with conventional lighting.
    Any opinions?
  2. #2
    Member
    Join Date
    Mar 2009
    Posts
    25
    Limington, Maine
    Bolens
    Default Re: LED Lights
    I want to do the same, whats the issue? I like led's, plus you can get more lights with much less voltage. I would have all LED's if JD had led headlights.
  3. #3
    Platinum Member dusty3030's Avatar
    Join Date
    Jun 2008
    Posts
    873
    Arkansas!
    JD 4120, 400x loader, bucket, bale spear, pallet forks
    Default
    I think the only issue is with LEDs and older trucks is thermal flashers. If your blinkers won't blink swap out the flasher for an electronic one and you will be good to go.
  4. #4
    Gold Member Monster5601's Avatar
    Join Date
    May 2010
    Posts
    361
    Oakland, MI
    Kubota B3030 R4 Tires
    Quote Originally Posted by dusty3030 View Post
    They also make loads that simulate the current pull of a bulb to allow the old style flashers to work.
    Bob, n8zcc
    Kubota B3030 with R4s
    LA403, 60" bucket with hooks, bolt-on tooth bar, ratchet rake
    BH76 with 16" bucket and thumb
    Kubota Pallet Folks
    Bush Hog 35-06 72" Rear Blade
    Bush Hog SBX60 Box Blade
    Bush Hog Razorback RZ160
    Kubota ZD323-60
    Kubota RTV900 with Curtis hydraulic angle plow
  5. #5
    Elite Member Ductape's Avatar
    Join Date
    Feb 2006
    Posts
    4,791
    Central New Hampshire
    Kubota B3030HSDC
    This is right on the money. I've swapped out many incandescents for LEDs over the years.
    I'd like to see some pics of your B model !!
  6. #6
    Join Date
    Dec 2010
    Posts
    553
    Bolton, MA
    Guys thx!
    Ductape -here you go:
    Attached Thumbnails Attached Thumbnails LED Lights-dsc00008.jpg   LED Lights-100_1064.jpg   LED Lights-100_0677.jpg
  7. #7
    Veteran Member JohnDeere4300's Avatar
    Join Date
    Feb 2005
    Posts
    1,564
    Eastern, Kentucky
    John Deere 4300
    WOW!!!... That is a very nice truck!!!
    Thanks for sharing!!!... I want it!!!
    I didn't know there was an issue mixing LED's with conventional lighting.
    Bill
    John 3:16
    01 JohnDeere4300 "Sync-Reverser", Vertical Exhaust, 2 JD Lawn Tractors, JD Walk Behind.
    430-FEL/ 47-Backhoe/ 5' Bush-Hog/ Single Bottom Plow/ 6' Disc/ 60'' Tiller/ 72'' Rear Blade/ Aerator Spreader/ HF Quick-Hitch!
    (Homemade Stuff) BH Thumb/ Log-Hitch/ 10' Boom-Pole/ 42'' Pallet Forks ''FEL Quick Attach & 3PH Quick-Hitch-Attach''/ Ballast Box 1381 lbs./ Aluminum Canopy/ Brush-Guard Mod/ 5x10 Firewood Trailer/ Lawn Striper.
  8. #8
    Join Date
    Jun 2008
    Posts
    873
    Arkansas!
    Default
    Your truck is awesome. Looks great.
  9. #9
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,937
    Pennsylvania
    Kubota BX25
    Love the old Mack!!! Awesome truck!!!!
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  10. #10
    Join Date
    Feb 2006
    Posts
    4,791
    Kubota B3030HSDC
    Quote Originally Posted by Red Horse View Post
    Beautiful ! Do you take it to any of the ATHS or ATCA shows? It doesn't look farmiliar, but I always go to Barrington (NH) and Hudson..... and any other shows I can squeeze in.
Similar Threads
  1. LED Lights
    By SpringHollow in forum Power Trac
    Last Post: 02-06-2013, 08:40 AM
  2. LED work lights with integral on/off switches ?
    By FritzII in forum Parts/Repairs
    Last Post: 01-18-2013, 10:25 PM
  3. LED Lights
    By MikeyB in forum John Deere Owning/Operating
    Last Post: 11-23-2012, 08:07 PM
  4. Lights, Camera, Action
    By 4shorts in forum Customization
    Last Post: 11-30-2009, 06:00 PM
  5. Seems to be an OK baby tractor so far
    By HomeBrew2 in forum Owning/Operating
    Last Post: 01-24-2005, 01:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
