Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    646
    Ct
    Yanmar 2020D
    Default 7 Pin connector ...loose?
    I was trailering this past weekend and my tekonsha would blink red everytime I hit a bump and tell me the trailer was disconnected. I noticed that because of the stiff cable from the trailer that it torques itself into the female socket on the truck and makes it loose. Anyone have a fix?
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Zip tie it in or get a soft coil cable like a big phone cord. You can cut off the old and splice it in or just get one that is a extension cord and coil up the old cable and zip tie it off to the trailer frame.
    Chris
  3. #3
    Join Date
    Feb 2010
    Posts
    646
    Ct
    Yanmar 2020D
    Default Re: 7 Pin connector ...loose?
    I thought of a zip tie - but no real way to attach it. Any chance you have a pic of those coil cords - and where the heck do you find them?
    Thanks,
    Scotty Dive
  4. #4
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    The door latch on the truck's receiver should have a little hook that stops the plug from pulling out or coming loose. Does yours have that?
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  5. #5
    Join Date
    Feb 2010
    Posts
    646
    Ct
    Yanmar 2020D
    Default
    Mine does not have that.
    Thanks,
    Scotty Dive
  6. #6
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    Default
    If the trailer plug has the little lip, replace the trucks receiver. They are pretty cheap and easy to install.
    Derek
    Kioti CK20HST
  7. #7
    Elite Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    4,697
    Northern Vermont
    I had that problem when the door broke off my 7 pin connector. The day i noticed it I was in a hurry and didn't replace it. While driving down the interstate the plug came out and before I realized it I wore down the trailer connector pretty badly (it's one of the molded cable/ connector style). Replace it before you end up replacing more parts.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer
  8. #8
    Veteran Member dstig1's Avatar
    Join Date
    Apr 2010
    Posts
    1,906
    W Wisc
    Kubota L3130
    Quote Originally Posted by Scotty Dive View Post
    Hopkins Flex-Coil Power Connector – 7 RV Blade to 4 Flat | Trailer Lighting | Northern Tool + Equipment
    Not the right connectors, but the gist of it...
    -Dave
    "Being a pessimist is great. You can't lose. Either you end up being right...or you are pleasantly surprised."
    L3130HST, QA, 723 Loader, 48" Forks, 48" Grapple, Ancient Farmi Skidding winch
    Trailer - 10k/16' twin axle w/elec brakes
    2005 F250 5.4V8(3V) 3.73/4wd tow vehicle
  9. #9
    Silver Member Oldtractorfixer's Avatar
    Join Date
    Mar 2012
    Posts
    219
    Oregon City, Oregon
    several
    Field fixes I have used include take a piece of twine and loop it next to the plug as you put it in jaming the socket. Another way is loop a bungee around the cord behind the plug and the hook both ends to the truck. Those work till you can fix it properly. There should be a mechanical lock as in in the previous post. Usually if the contact posts are tight they still stay. I think you probably have worn or colapsed pins in addition to the missing lock. Sometimes you can get more tension and a better contact taking a knife or small screwdriver and spread the pins open if they are the split kind.
  10. #10
    Gold Member
    Join Date
    Nov 2011
    Posts
    385
    Louisville, KY burbs
    My small trailer did a similar thing last week. I also thought my connector was getting loose, but it turned out to be a combination of that and dirt in the connector causing it to make poor contact. A few minutes with the air compressor seemed to help as I don't have to jam it in there with comic book strength to make the lights stay on now.
Similar Threads
  1. 7 pin connector corroded?
    By Wayne_H in forum Trailers & Transportation
    Last Post: 10-27-2011, 09:13 AM
  2. Ford 800 hard steering to left
    By george46 in forum Parts/Repairs
    Last Post: 08-15-2011, 01:17 PM
  3. Backhoe Woods Backhoe Pin Problem - suggestions?
    By Jay4200 in forum Attachments
    Last Post: 10-19-2006, 03:58 PM
  4. Dump Truck snaped a pin!!
    By EddieWalker in forum Construction Equipment
    Last Post: 10-08-2006, 08:21 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
