Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 58
  1. #11
    Join Date
    Feb 2008
    Posts
    113
    Wisconsin
    2008 AgroPlus 87
    Default Re: Trailer capacity on F450,F550,F650
    I have seen those link pages but they do not give any information on custom made weld-on butt hitches but if I assume it doesn't increase capacity then it rules out everything below a F650 in size. As far as the F650 nothing is listed as far as the capacity for coventional towing. It say contact your local dealers and all they say is I am ok with my current 21K pintle trailer pulled by my F650. My current F650 has hydraulic brakes and an air suspension rear end. It is rated at 26,000 gvwr, weighs around 12K with a combined pulling capacity of 40K. The best that I could gather from various sources is that I can pull a pintle hitch up to the capacity of the truck rating which is my case would be 26K. As far as the pintle hitch trailer at 21K I can at times come close to it being fully loaded and even then the F650 pulls it easily. I agree converting to a gooseneck would be the best option but so far haven't found anyone able to do the conversion. I plan on calling some metal fabrication shops this week but if you know of someone even in UP that would be great. If that could happen then a modern F350 - F550 would work for me.
  2. #12
    Silver Member trailbuilder's Avatar
    Join Date
    Mar 2011
    Posts
    140
    Ironwood Michigan (Northern Michigan...by Lake Superior and Wisconsin)
    JD 333E, JD 333D, JD 328D, JD 450J, JD 50 D, CASE 621C,JD 4210,JD 3346,JD 5093,JD 825i, PB10050.
    Do you have any pictures of the trailer...that would help us.
  3. #13
    Gold Member Wnc3's Avatar
    Join Date
    Feb 2012
    Posts
    377
    S.E., Texas
    John Deere 820 utility, John Deere 5525, 997 JD Zmower, Komatsu PC 35 miniExcavator
    If you don't go with a gooseneck....
    To increase your tongue weight you will want the hitch just behind the rear spring hangers. (That is not possible with a standard pickup bed.)
    Btw....all the diesel pickups will pull the weight. The problem is stopping.
    If you step up to the 650 or 750 get the air brakes.
    And another thing, everyone on this site seems to be of above average intelligence so go get your CDL and check it off your list. It is not that big a deal.(this is a general statement not directed at OP)
  4. #14
    Veteran Member powerstroke444e's Avatar
    Join Date
    Jan 2008
    Posts
    1,231
    Near Springfield IL
    mostly orange
    I have a older f450 and it will handle a 10ton pintle ok if the trailer is loader properly most of the time I have a 14K trailer behind it loaded at 14K or a little more its plated for 16k on the trailer and 16k on truck, and a little dirt or sand on the dump. My truck has 10' frame which helps balance it.
    With the pintle its on a 3/4plate welded to the frame. If I were doing 21K daily go with 5500 dodge if was wanting 4wd or a f650 for a little more truck and you can get air brakes. My uncle has a single axle old mack that we pull a 25ton trailer with but its slow.
    Attached Thumbnails Attached Thumbnails Trailer capacity on F450,F550,F650-image_578-jpg   Trailer capacity on F450,F550,F650-image_586-jpg
    If it ain't smokin' it's broken.
  5. #15
    Join Date
    Feb 2012
    Posts
    377
    S.E., Texas
    Quote Originally Posted by powerstroke444e View Post
    Perfect example of a hitch just behind rear spring hanger. And, as you said, the longer frame help the front end stay down. Nice rig...
  6. #16
    Join Date
    Feb 2008
    Posts
    113
    Wisconsin
    2008 AgroPlus 87
    I did find someone willing to do a conversion but decided that would not be a wise option. The issue is the DOT looks at any modification from a tag along to gooseneck as changing the manufacturers design. The manufacturer would have to sign off on it and even if the DOT approved it I still have to deal with the insurance company and if anything happens I might as well change my name --- just not worth it! So at the end if I really want to go with a smaller truck than the F650 living with the 17,500 lbs for the tag along is not the best but it will cover me most of the time. I guess my F650 will live on for a few more years (see attached)
    Attached Thumbnails Attached Thumbnails Trailer capacity on F450,F550,F650-special-038-jpg
  7. #17
    Elite Member Duffster's Avatar
    Join Date
    Mar 2009
    Posts
    4,372
    Wisconsin
    Quote Originally Posted by ahlkey View Post
    Getting a conversion done isn't nearly that big of deal. I think you are way over thinking that part.
    "If everyone is thinking alike, someone isn't thinking." George Patton
  8. #18
    Join Date
    Feb 2008
    Posts
    113
    Wisconsin
    2008 AgroPlus 87
    Thanks Duffster. I gave it another look and called DOT and it is not that problematic. I also received a reference of another company that is very experienced in doing conversions to goosenecks so we will see if it pans out.
  9. #19
    Join Date
    Jan 2008
    Posts
    1,231
    Near Springfield IL
    mostly orange
    Nice set up.
    I would think with that trailer you could move to a dodge 5500 or F550 and still safely tow in 25K range at least in my neck of the woods, but in the mountains not so much.
    I had f350 and this trailer set up for several years and always did fine trailer and load were in the 18/22K range. And it is legal as I was plated for 32k total load. And went through several roadside DOT stops over the years with no issues.
    Please remember around here large grade is the on ramp on the interstate.
    Attached Thumbnails Attached Thumbnails Trailer capacity on F450,F550,F650-img041-jpg   Trailer capacity on F450,F550,F650-trencher-jpg
  10. #20
    Join Date
    Feb 2008
    Posts
    113
    Wisconsin
    2008 AgroPlus 87
    I got two quotes now for the conversion to a gooseneck from my current tag along trailer. Both companies actually manufacturer or modify heavy truck trailers for both the farm & construction industry. It's good to have someone with a long history of doing this right. I am going to go forward with the modification in the next month or so. The trailer will keep the same capacity rating I have it titled under (20K) today but now I can go to a smaller 4 X 4 truck to pull it. The F350 with a single cab/diesel 6.7, dually with the 3.73 slip axles can pull 22,200 lbs with a gooseneck setup.. My other larger trailer shown above is a gooseneck rated at 22K.
Similar Threads
  1. At Home In The Woods
    By Obed in forum Projects
    Last Post: 08-11-2017, 09:31 AM
  2. Trailer Thefts in Tarrant and Parker Co. Texas
    By two_bit_score in forum Rural Living
    Last Post: 09-01-2009, 08:47 AM
  3. Need bigtime help on trailer decision
    By LabLuvR in forum Trailers & Transportation
    Last Post: 03-24-2008, 10:05 AM
  4. Bought a trailer for my Kiota ck20 today
    By rimshot in forum Trailers & Transportation
    Last Post: 02-10-2008, 09:31 AM
  5. Which Axles for Trailer?
    By cjcocn in forum Trailers & Transportation
    Last Post: 12-31-2007, 10:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
