Dump Trailer Tool Box
   / Dump Trailer Tool Box
Did you notice my oil reservoir for the pump ? I had an old 20# propane tank that I cut in half. Took some 10 guage sheet and welded it to the top where the pump is mounted. I was surprised how much oil to took for a six inch cylinder to press the ram to the end. There is still 2 " to the top plate for additional oil. ( minus the size of the pump under the plate ) It was fine to figure strong than be a pint short and start the process over. I was under the impression by the manufactured pumps with a gallon reserve tank attached it would be all the oil needed for the application. Shows one needs a little math calculation ( or fill and empty the hydraulic cylinder ) to make sure the quanity of fluid is sufficient for your application. I hate doing things twice !
   / Dump Trailer Tool Box #22
Good use of stuff on hand.
Beats paying someone else to make it!
   / Dump Trailer Tool Box #23
Nice job.
Chris
   / Dump Trailer Tool Box #24
I added more storage space under my trailer. It is SO worth it.
Takeuchi TL150 High Flow Compact Track Loader Skid Steer (A59228)
Takeuchi TL150...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
2014 VOLVO L45G WHEEL LOADER (A60429)
2014 VOLVO L45G...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
WATER TRAILER (A58214)
