Results 1 to 10 of 10
  1. #1
    Veteran Member JDGREEN4ME's Avatar
    Join Date
    Sep 2002
    Posts
    2,250
    Southeast PA
    John Deere 2520, John Deere X534, LT150, STX 38
    Default trailer question
    What are the best locations to use on a tractor to secure it to the trailer?. I have heard some people chain around the front axle but that seems you could break something. I was planning to hook onto the front weight bracket and to the drawbar on the rear. This make any sense? I am open to ideas...I could not find anything in the manuals...thanks...
  2. #2
    Join Date
    Mar 2003
    Posts
    781
    Finger Lakes Region, NY
    Kubota BX1800
    Default Re: trailer question
    I don't know if those areas are the best, but that is where I do it on my kubota BX1800 as well. I also didn't like the idea of the axles figuring that could possibly damage something.
  3. #3
    Veteran Member Will_C's Avatar
    Join Date
    May 2002
    Posts
    1,687
    Upstate N.Y.
    Kubota B 2620, Toro 52" and 60" ZTRs, Kubota RTV 900
    That is what I do. Using a shackle on your drawbar works well.
    Will
  4. #4
    Join Date
    Apr 2003
    Posts
    115
    JD 2210
    Hi Mr Green
    I had a guy do some yard work for me before I got my tractor and he had a pretty slick way. He had a quick attach 3 point, he then had a rod going across the front of the trailer, just backed on the trailer and raised the 3 point till the quick attach locked on the rod, thats all he used. I just ordered the JD Imatch, now if I only had a trailer,,,
    later
    Phil
  5. #5
    Join Date
    Feb 2002
    Posts
    105
    Milford, MI
    JD 4100
    Watch the drawbar. If you crank down on it, it will bend. Nothing severe, but it will bend.
  6. #6
    Join Date
    Mar 2003
    Posts
    781
    Kubota BX1800
    I actually hook mine to the inside of the drawbar with straps. The attached picture shows where I attach the straps to the rear of my unit now (only one side shown)
    I first bougt a clevis to go through the drawbar, but the other day decided to try this spot and I like it much better.
    Attached Images Attached Images
  7. #7
    Join Date
    Mar 2003
    Posts
    781
    Kubota BX1800
    This picture shows how I was doing it with the clevis, of course I had two straps pulling from opposite directions, but it still only gave a single point on the tractor and if one broke would have loosened the other without the tractor even moving so that is why I have changed now. If one breaks now, the tractor has to move also.
  8. #8
    Join Date
    Sep 2002
    Posts
    2,250
    Southeast PA
    surfran,
    Thanks for the photos...I have a clevis on my drawbar now, sort of what I was thinking about. I like the drawbar set-up on your tractor better than what I have. Where abouts in the finger lakes region are you located? We are planning to build on land we bought by Seneca Lake.
  9. #9
    Elite Member
    Join Date
    Oct 2000
    Posts
    3,061
    Windham County, Conn
    Ford 2120 , New Holland TN75D, Hitachi UH083LC Excavator
    On My machines, Ford 2120 and TN, I wrap a chain right around the rear axle for the rear. In the front. I wrap a chain around the front weight brackets. I've never been a fan of securing using anything hitched to a 3 point attachment. I want a secure hitch right to the main part of the machine. You may be okay on lighter machines, but on the 2120 and the TN the rear axle is very strong and like I said it's defiately the only place I feel comfortable securing. An exception to this is that I'll grab the frame of the Woods 1050 hoe on the TN if the hoe is mounted. It's not about to fall off either.
    Andy
  10. #10
    Elite Member Gary_in_Indiana's Avatar
    Join Date
    Apr 2002
    Posts
    3,388
    Fort Wayne, IN
    John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
    I use the front axle and the backhoe on the rear most of the time. When the backhoe is off, I hook to the drawbar or rear axle depending on what else I've got going on at the time.
    I have to trailer my tractor this weekend and I'm going to try something a little different just to see how I like it. I'm going to back my tractor to my trailer then begin winching it up onto the bed with two J-hooks and a pear ring.
    When I get it to near where I want to stop it, I'm going to loosely strap the front axle to the floor then winch it on further until those connections are tight. My winch has a brake on it so I should be OK with that end. I will, however, still attach safety chains. [img]/forums/images/graemlins/smile.gif[/img]
    Remember, a safety chain isn't just a good idea, it's the law. [img]/forums/images/graemlins/wink.gif[/img] [img]/forums/images/graemlins/smile.gif[/img] [img]/forums/images/graemlins/grin.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
