Results 1 to 4 of 4
  1. #1
    Gold Member
    Join Date
    Mar 2004
    Posts
    433
    Texas Panhandle
    case jx95 with cab
    Default 7 way vs 6 way trailer plugs
    Years ago it seemed like the six way round metal trailer plugs were the most popular. Now it seems every truck or trailer I buy has the big plastic seven way. I don't need the functionality of the seven way but am thinking of changing just to be more standard and to quit having to change every thing I buy. Do the seven way connectors work well and hold up over time?
    2006 Case JX95
  2. #2
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,059
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 7 way vs 6 way trailer plugs
    around here, the 6 way are usually found on ag trailers .. and also on discount trailers. i guess the 1$ they save when buildingthe trailers makes a difference int hat 6 vs 7 debate. anything with no brakes is getting the 4 flat.
    I used to keep a 6 way on the truck for a couple ag trailers, but now have everything 7 and use a 7 to 6 adapter if AI need to use my ag trailer. when the 6 ways on the trailer wear out eventually.. I'll upgrade to 7 just because...
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    I work with trailers every day, maybe 75 of them a year. 99.9% are 7 pin. I have not delt with a 6 pin since about 2004 and the first thing I did with it was cut off the 6 pin and put on a 7. Reverse is what you gain with a 7 pin and its necessary for any trailer with disc brakes which are now the standard in the marine industry.
    Chris
  4. #4
    Silver Member droptop's Avatar
    Join Date
    Jan 2012
    Posts
    141
    Western NY
    Massey Ferguson 1635 cab
    The 7 pin seem to hold up quite well and make a good connection due to the large flat contact surfaces.
Similar Threads
  1. ts1910 plugs
    By abee6743 in forum Iseki
    Last Post: 03-17-2011, 12:02 AM
  2. Glow Plugs
    By ctjstr in forum New Holland Owning/Operating
    Last Post: 02-19-2008, 06:17 AM
  3. ? on glow plugs
    By whitearrow in forum John Deere Owning/Operating
    Last Post: 06-02-2006, 02:33 PM
  4. Glow Plugs
    By Yardscaper in forum Power Trac
    Last Post: 12-23-2004, 04:07 PM
  5. Changing plugs
    By outridder in forum Power Trac
    Last Post: 03-22-2004, 11:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
