Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Join Date
    Jun 2006
    Posts
    193
    Default Re: Truck Faltbed Project
    Quote Originally Posted by tlbuser View Post
    POR-15 is pretty good for a rust restorer type paint. With diamond plate, it's tough to get the nooks and crannies unless you're media blasting. Eastwood has a ceramic chassis black which we just used on a couple of frame jobs. It's an epoxy type and not too hard on the wallet.
    Eastwood 2K Ceramic Chassis Black Kits
    That's gonna be a nice truck when you're done with it. The trough can make life easier, but so do power jacks.
    TLBUSER,
    Thanks for the infon on the Eastwood, I'll do some reading on it.
    As for the power jacks... My only experience was on a 2003 LQ horsetrailer that I used to drag around the country. It was a 4 horse, with mid tack, slide out, and 16' short wall. It was one heavy SOB, and the dual jacks were operated by an electric motor and chain drive. If for some reason the batteries were down on the trailer, I would have to hand crank, on the low speed, and if I recall correctly, I think I cranked something like 50 times for an inch of elevation... Anyhow, I have considered going to a hydraulic jack setup on a couple of my larger trailers, but haven't made the decision to spend the coin yet...
  2. #12
    Super Member dodge man's Avatar
    Join Date
    Oct 2008
    Posts
    5,182
    West central Illinois
    Kubota BX2350
    I had some POR15 once, but I don't remember the details. It seemed like it was a prep type coating, not a final coat. As I recall, it could just be brushed on, and it was meant to convert/neutralize the rust for painting.
    There are time I wish I had a flat bed, but I think the look better on dual rear wheels than singles.
    Dave,
    BX2350
  3. #13
    Join Date
    Jun 2006
    Posts
    193
    Quote Originally Posted by dodge man View Post
    I agree that with you about the flatbeds looking better on a DRW than a SRW. That said, I still run a flatbed on my 2002 Dodge 2500 4x4 SRW.
    Here's a pic of my "day rig" The trailer is a 16x5 half top, and is the exact width as the SRW truck.
    Truck Faltbed Project-305121_10150328272727407_474661875_n-jpg
    Truck Faltbed Project-301180_10150260542372407_6243428_n-jpg
    Here is a backside shot showing the trough that I cut in a while back.
    Truck Faltbed Project-268851_10150232093687407_2626246_n-jpg
    Attached Thumbnails Attached Thumbnails Truck Faltbed Project-206128_10150251328942407_6539011_n-jpg
  4. #14
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Quote Originally Posted by CCOUGHRAN1 View Post
    After seeing the flatbed on the truck, I did not care for how the side skirts lined up with the body on this truck, so I decided to cut them off and
    Be sure to make it a dump bed.
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  5. #15
    Join Date
    Jun 2006
    Posts
    193
    Made some more headway on the flatbed yesterday.
    Rear skirt, and both side skirts are installed. I still need to weld on the safety chain tie downs, and the stake pockets and rub rail.
    Truck Faltbed Project-imag0538-jpgTruck Faltbed Project-imag0539-jpgTruck Faltbed Project-imag0536-jpg
  6. #16
    Join Date
    Jun 2006
    Posts
    193
    I appreciate all of the input on the paint. I ended up going the easy route, which I may regret down the road...
    I shot it with 3 coats of Rustoleum gloss black oil based paint. Also managed to get the tail and marker lights installed. Still need to hang the mudflaps, install a license plate light, hook up the fuel filler hose, and install the aux. fuel tank/toolbox combo.
    Rub rails installed, still needed to install the headache rack bracing in this pic
    Truck Faltbed Project-484607_10150891368452407_748054976_n-jpg
    Truck Faltbed Project-480722_10150895402062407_1460447640_n-jpg
    Truck Faltbed Project-541689_10150895402397407_1424794729_n-jpg
  7. #17
    Super Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    5,096
    Peoria IL
    New holland TC(33)
    I've never tried to do a spray on liner at home, nor have I used POR15... Any tips or tricks to applying either of them?
    spray on bed liner can actually be rolled on with decent results espeically for diamond plate surface. there are plenty of vids on youtube showing people useing a simple HF undercoating gun to spray it on with really good results.
    Por15 is nasty stuff. Dont plan on cleaning anything up. plan on tossing the brush, wear gloves and drop cloth anything on the ground you dont want to be covered in splotches of paint for the rest of your life. Creates a hella hard paint that will last forever.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  8. #18
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    CC, it looks real good with the gloss black.
  9. #19
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    looking good!
  10. #20
    Join Date
    Jun 2006
    Posts
    193
    Thought I would post up an update on the flatbed project. I have now installed all the LED lights, including some green LED's in the gooseneck trough to give some soft light to see while hooking up a trailer in the dark. I've also installed the fuel tank / toolbox combo, the ice chest, some dog snaps with vinyl coated cable, and stainless steel fasteners.
    When all of that was done, I saw an open spot on the bed, just to the right of the toolbox, that looked like the perfect place for an accessory I've been wanting, a gasoline air compressor.
    Truck Faltbed Project-imag0561-jpg
    So, I did some research and shopping, and placed the order last week. The compressor came in last night, and I broke out some more stainless bolts and mounted it to the bed.
    Truck Faltbed Project-imag0589-jpg
    Truck Faltbed Project-imag0590-jpg
Similar Threads
  1. turning a 3/4 ton truck into a dump truck??
    By BWS in forum Attachments
    Last Post: 08-04-2016, 01:49 AM
  2. New To Me Truck
    By CLinton_in_FL in forum Trailers & Transportation
    Last Post: 04-30-2011, 11:19 AM
  3. I need a new (used) truck
    By _RaT_ in forum Rural Living
    Last Post: 04-15-2010, 07:59 PM
  4. Dump truck project (Mirror Question)
    By afish in forum Trailers & Transportation
    Last Post: 03-16-2009, 12:53 PM
  5. What to look for in a used truck
    By GrantMO in forum Rural Living
    Last Post: 05-13-2002, 10:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
