LHS Inc
Gold Member
- Joined
- Nov 16, 2010
- Messages
- 357
- Location
- Eastern Shore, Maryland
- Tractor
- JD 3520 eHydro w/300CX FEL
You need a bigger trailer and to get your hitch situation sorted out. You are hauling for a commercial business and are expected to know what you're doing. No reason that you shouldn't be able to pull onto the trailer, set the implements down, chain up, and drive off. All this jacking around with unbolting the tail wheel and removing the bucket just to make the gear sort of fit onto the small deck is very unprofessional.
I see that the tractor is apparently nearly new. You'll get it figured out soon. The biggest infraction I see is not using a wdh, or even knowing what it is when it is probably required for your truck to tow anything more than a tiny trailer.
You mean to tell me I have a 3/4 ton HD with a tow capacity of 10,000 lbs and tongue weight of 1000 lbs and all I can haul is a "tiny trailer" without a WD hitch?
During my recent MD DOT saftey audit they said I'm in compliance because the truck is a 3/4 ton with HD rear and springs. They can bust you for towing with a 1/2 ton because its not heavy enough for what I'm doing.
Got the yearly DOT truck and trailer inspection and it was approved by the US DOT.
Both US and MD DOT know just what my traller is rated and tagged for ( 10,000 lbs ) and they know what the truck hitch is rated for (1000 lbs.)
There was no mention of needing a WD hitch. They are the ones I have to answer to and they like what they see.
I have yet to see a WD hitch on anything except a vehicle pulling a camper or boat in which the vehicle was undersized to tow.
I'm not saying I'm against having one. If I keep my trailer I'll probably get one now that I've learned more about them and if it will help the truck and trailer to ride safer and look better I'm all for it.
If I was to get a longer trailer that would balance the load would you all still suggest a WD hitch?
Yes the tractor is new, a 2010, so I'm just getting into hauling it around for jobs. Every implement except for the rotary cutter fit on the trailer with room to balance the load.
I agree with what you said in that its a pain to have to go all thru the fanaggling of getting the tractor to fit the trailer. Thats the way it will have to be until I decide whether to get a bigger trailer or not. Once a month isn't a big deal but it would be nice to just run it on chain it down and drive away whistleing as I cruise down the road.
Thanks for all the input.
