Results 21 to 30 of 36
11-14-2012, 03:15 PM #21Veteran Member
- Join Date
- May 2012
- Posts
- 2,251
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Re: Spring Over Axle (SOA) trailer conversion
BTW, the kit is $50, but that's only for one axle, so for a tandem, you're in for about $100. Since the kit comes with new U-bolts and nuts, it's not actually THAT much more expensive than welding on new spring perches. Spring seats are about $8. The U-bolt kit is about $16. So the Dexter SOA conversion kit is twice as expensive as welding on new perches yourself. If you have a welder and know what you're doing, it's no debate. But when you add in the hassle of transporting your axles to a welding shop and the cost of getting the new perches welded on, it's a no-brainer. For a tandem-axle trailer, the added cost of the kit is $50. As far as I could tell, that's basically the job minimum for most welding shops around here, so I basically broke even.
11-15-2012, 01:19 AM #22Platinum Member
- Join Date
- Feb 2012
- Posts
- 539
- Location
- sioux city, ia
- Tractor
- Oliver 1855, Case 1840, Cub 1550
Thanks for the link.
Dave
11-15-2012, 02:17 AM #23Veteran Member
- Join Date
- May 2012
- Posts
- 2,251
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
11-15-2012, 09:33 AM #24Platinum Member
- Join Date
- Feb 2012
- Posts
- 539
- Location
- sioux city, ia
- Tractor
Ok thanks, did you get any pics of the your trailer as it sets now, did you have to change your hitch ball height?
Dave
11-15-2012, 01:18 PM #25Super Member
- Join Date
- Apr 2000
- Posts
- 7,591
- Location
- Shingle Springs California
- Tractor
- New Holland TC40D
11-15-2012, 01:23 PM #26Super Member
- Join Date
- Apr 2000
- Posts
- 7,591
- Location
- Tractor
- New Holland TC40D
11-16-2012, 08:10 PM #27Veteran Member
- Join Date
- May 2012
- Posts
- 2,251
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
I took a picture for you today, Dave. Unfortunately, I don't have a "before" picture for you to compare it to, but just imagine it 5" lower
I did have to change the hitch ball height, but that was sort of the point. With the ball at its old height, the torsion bars of the WD hitch scraped the ground. I actually had to buy a much longer shank for my WD system in order to get the head low enough to let the trailer ride level. Raising the trailer let me go back to the original shank, which is significantly lighter. You may think I'm just whining, but the difference in weight between a 6" shank and a 13" shank is probably 30 lbs. They're solid 2" steel.
11-16-2012, 08:12 PM #28Veteran Member
- Join Date
- May 2012
- Posts
- 2,251
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
11-16-2012, 11:06 PM #29Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,473
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
I am sure it is set up the way you want it now but to me it just looks funny with all that room in the wheel wells. Looks like some of the 3/4 ton trucks that certain brands make and put tiny little tires on.
Chris
11-16-2012, 11:21 PM #30Veteran Member
- Join Date
- May 2012
- Posts
- 2,251
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
The problem is, it is simply unusable with a WD system at the ride height that it was, and I can't go over 3500 lbs on my current truck/hitch without a WD system. I suppose I could have addressed the issue with a class V hitch and no WD system, but there are other benefits to a WD system that I would rather not give up. Also a class V hitch runs about $300, while the SOA conversion was about $100.
If I'm really motivated, maybe some day I'll grind out the tacks holding the fenders on and lower the fenders...
Similar Threads
Axle spring seat welding
By ericher69 in forum WeldingReplies: 5Last Post: 05-27-2012, 02:39 PM -
GC2310 front axle spring clip
By Mac clarke in forum Massey Ferguson Owning/OperatingReplies: 10Last Post: 05-13-2011, 09:20 PM -
4 Wheel Farm Trailer Conversion to Tandem(?) Axle
By BobRip in forum Power TracReplies: 7Last Post: 07-25-2006, 05:43 PM -
Tandem axle Trailer,rear axle stuck off the ground
By jjcc246 in forum Parts/RepairsReplies: 14Last Post: 10-07-2005, 07:23 PM -
Trailer axle/leaf spring configuration?
By Scozz in forum Build-It YourselfReplies: 13Last Post: 11-21-2004, 01:29 PM
