Results 1 to 6 of 6
  1. #1
    Join Date
    Oct 2011
    Posts
    1,963
    Monrovia, California
    Kubota BX25
    Default 3 Way Tipping Trailer Hinges
    Does anyone have a link for 3 Way Tipping Trailer Hinges?
    The ball and socket variety?
    TIA!
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  2. #2
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,254
    Lakes Region, Maine
    M 9540 Kubota
    Default Re: 3 Way Tipping Trailer Hinges
    I wonder if you could use a trlr. ball (4) and just the right size and legnth pipe, maybe sch. 80 for the socket.
    You could drill a small hole just in the right spot for a "keeper" pin that would keep your pinned pair of hinges the pivot point. This leads to the next question of the cyl. mounting and location. From what I remember seeing, the cyl. is right in the middle of the body and usually a vertically mounted telescoping type. Show us what you find.
  3. #3
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Yes, and thnk you Rusty for the reply.
    I do not see that it is rocket science BUT,
    I still want to find them and "shop" them..
    If I were to do it, I would probably go w/ a
    2.125" ID DOM tube perhaps...
    Regards,
    Artisan
  4. #4
    Join Date
    Mar 2011
    Posts
    4,254
    Lakes Region, Maine
    M 9540 Kubota
    What's your application? At first what came to mind was the smallerish trailer, 2 axle, towed by a tractor, I remember seeing orange color ones at the JD dealer that did a lot of work with the golf courses. But now I remember on some of the "town" snowplow trucks up here have a crazy forward and sideway dumping bed to feed salt sand to the spinner. If I get a chance I'll stop in there and see what I can lean. At least the body make.
  5. #5
    Join Date
    Oct 2011
    Posts
    1,963
    Kubota BX25
    Click HERE Rusty
    Regards,
    Artisan
  6. #6
    Super Member
    Join Date
    Jul 2009
    Posts
    9,003
    SW WA
    Kubota BX2360
Similar Threads
  1. Just built my tipping trailer
    By fixit in forum Build-It Yourself
    Last Post: 06-03-2011, 04:59 PM
  2. Trailer Tipping
    By trek5900 in forum Trailers & Transportation
    Last Post: 02-03-2010, 06:00 PM
  3. A tipping trailer for my CUT
    By soulasphil in forum Attachments
    Last Post: 08-27-2009, 08:55 PM
  4. New Tipping Trailer
    By voodoo in forum Attachments
    Last Post: 03-17-2003, 05:28 PM
  5. New Tipping Trailer
    By voodoo in forum Trailers & Transportation
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
