Results 11 to 20 of 58
10-04-2012, 09:43 PM #11
- Join Date
- Jan 2007
- Posts
- 16,332
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Originally Posted by Red Horse
Chris
10-04-2012, 10:06 PM #12
- Join Date
- Feb 2002
- Posts
- 5,315
- Location
- western,pa.
- Tractor
- Kioti DK 35
Re: Binders - Which Kind?
For years I loaded/unloaded equipment every day using the flip over/snap style binders.
A lot of my friends and co-workers keep telling me how dangerous they were and I should be using the rachet binders.
Paid no attention to their warnings till a binder handle slipped out of my hands and fractured my skull.
An ambulance ride and a stay in the hospital made me start using rachet binders.Vince,
Kioti DK 35
Hustler Super Z
10-04-2012, 10:08 PM #13
- Join Date
- Apr 2012
- Posts
- 743
- Location
- pa
- Tractor
- kubota 7040sud
rachet binders i have a reg binders i cant use them with use of one hand rackets are the way to go get the harbor fright binders just to make sure you take em apart and clean the shavening out of them before you use them i learned the hard way
10-04-2012, 11:58 PM #14
- Join Date
- Feb 2011
- Posts
- 8,975
- Location
- Virginia
- Tractor
- yes
I have a couple of these from lowes and some older ones that are the same style. For hauling your jeep straps are fine, you may want to get a set of axle straps.
10-05-2012, 07:41 AM #15
10-05-2012, 09:23 AM #16
- Join Date
- Apr 2012
- Posts
- 1,075
- Location
- Central AL & MS Delta
- Tractor
- Mahindra 3510 and Mahindra 8560 Cab 4WD
My trailer manual says not to use the ratchet binders- over tighting will bow the trailer in time and can cause stake pockets to break under road stress. It also says to go through stake pockets and hook to trailer frame. I found a cheater pipe at a Kangaroo Fuel Stop that has a end that will release the binder without creating a flying club.
My brother is warehouse/shipping manager for a local steel company and they don't use the ratchet binders.
He says they are hard to tighten and will work loose on mixed steel loads if it shifts. They also get stolen off the loads all the time!PROUD AIR FORCE DAD
10-05-2012, 09:24 AM #17
- Join Date
- Apr 2012
- Posts
- 1,075
- Location
- Tractor
10-05-2012, 09:38 AM #18
- Join Date
- Jun 2008
- Posts
- 10,900
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Are you saying that breakover binders wont get loose if the load shifts? Not likely! Any tie down method will loosen if the load shifts, which is why you are supposed to check the binders or whatever a few miles down the road after everything settles in and then again every 100 miles or so.
As for over tightening, I would think that boomers would tighten move than necessary as you only have a chain link to adjust where one link might be a little loose and the next link really tight needing a big cheater. Sure you can likely put more pressure on a rachet if using a cheater pipe, but dont do that as the handle is long enough to put plenty of tighteness on the chains. Nothing is idiot proof and the driver needs to have some common sense when it comes to loading and securing.
I am more inclined to think that the reason that company uses boomers is because they are cheaper not better.2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
10-05-2012, 10:14 AM #19
I got a set of "Tie Down Tamers" from Erickson. Love them. They work real well to keep those annoying strap "tails" under control. Only takes a few seconds to roll up the unused straps. Cant say enough good about them they really neaten things up.
But they are nylon (10,000 lbs breaking) and if you run them over a something sharp without protection they will fray.
Review showing them in action,
Chains are excellent but come with their own problems. Unless needed for load capacity, careful nylon strap placement should get you through.
10-05-2012, 05:48 PM #20
I use ratchet binders as well. I have manual binders but switched to the ratchet type. It doesn't take too many times getting hit in the jaw, teeth or head to realize there must be a better way.
Similar Threads
which chains and binders should i use?
By bjess8 in forum Trailers & TransportationReplies: 56Last Post: 04-04-2010, 07:20 PM -
chain/binders
By buck12 in forum Trailers & TransportationReplies: 65Last Post: 06-01-2009, 04:21 PM -
Why four binders?
By n8586m in forum Trailers & TransportationReplies: 76Last Post: 04-04-2009, 07:27 AM -
Chain and binders
By Roger2561 in forum SafetyReplies: 35Last Post: 05-31-2006, 06:33 PM -
Why binders?
By MLB in forum Owning/OperatingReplies: 16Last Post: 06-29-2003, 11:59 PM
