cockeyedMFer
Gold Member
- Joined
- Jul 25, 2011
- Messages
- 270
- Tractor
- 1959 MF 35 deluxe, gas
Just picked up a '65 F600 to haul gravel and dirt for my driveway project and it has a factory 2 speed axle. Everything else on the old girl works great except the two speed selector.
There's power at the circuit breaker, the switch turns it on and off properly, there's power all the way into the motor, but nothing. I guess its seized from non-use, but isn't even rusty.
Checked the gear oil and its clean and fresh. Tried tapping it with no results.
The motor bolts to an adapter, which bolts to the axle housing. Are there any other tricks before I remove it? Is there anything that can fall into the housing if I unbolt the motor from the adapter?
