Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Join Date
    Sep 2012
    Posts
    78
    Weatherford, TX
    '69 MF 135
    Default Car Hauler vs Regular Flatbed
    I need to bring my tractor in to the dealer but do not currently own a trailer. They want about $100 one way. From what I can tell I need about an 18' and 20' would be even better for my needs. Would like to be able to throw a 6' disk my massey 135 and bush hog on the trailer for transport. Or my FIL's L3400 Kubota with 5' bush hog and loader. I feel like I am right on the edge of the 3500 dual axle trailer and 5000+axles.
    Secondly I have had to rent three uhaul car haulers within the last two years and would love the trailer to dual purpose as a car hauler but my car is awfully low to the ground and requires a dove tail and long ramps.
    Is it possible to get a standard railed flatbed with a dove tail? How useless is a traditional car hauler for farm use, hay, metal other assorted large items?
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,259
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Default Re: Car Hauler vs Regular Flatbed
    A 7000 lb trailer will be too light for you. A 10K# car hauler would work providing your tractors will fit between the fenders (maximum width you can find is very near 82"). Otherwise, a 10K# deck-over is in order, but they suck as car haulers because of the short beavertail and abrupt transition between deck & tail.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,448
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    My 18' car hauler with a flat deck and 5' slide in ramps has hauled three Corvettes with no issues. If I can haul a Vette I am sure I could haul anyyhing.
    Its a low boy and only 14" deck to ground.
    Chris
  4. #4
    Join Date
    Sep 2009
    Posts
    212
    Quote Originally Posted by scott123456789 View Post
    By traditional car hauler I am thinking with out side rails?
    I dont like having side rails, for me it gets in the way for alot of loads. Downside is you have tie everything down...which is not really a bad thing. I had a trailer built by C&M trailers in Ennis Tx.They are the MFG, and you eliminate the middleman. Mine is G/N but they also make the same version in a bumper pull. 20; with 10" channel drive over fenders. I had the deck in front and rear of fenders brought out to width of outside of fenders. I am 83" wide between fenders and 102'' wide with tie down rail in front/rear of fenders. I can load round bales 2 wide and stack on top in center. Plus I can load wide stuff like frames etc on top of the fenders and tiedown, if I need to I can use the fenders as a Tie down point also
  5. #5
    Join Date
    Sep 2012
    Posts
    78
    Weatherford, TX
    '69 MF 135
    My rear wheels are just set at 66" or so at the moment. And the Kubota is a bit narrower. I figured the 10K# would be needed. I thought the dove tail makes life a bunch easier. But perhaps with longer ramps that wouldn't even be needed. Really don't plan to haul the car but if I have a flatbed I want that to be an option with out farm vehicles etc.
  6. #6
    New Member
    Join Date
    Nov 2012
    Posts
    2
    Toolel,Ut
    Mahindra 4010
    They are pros and cons to both trailers. First let's do the car hauler
    Pro's Low to the ground, lightweigh,t easy to load.Con's may scrape the ground in lower areas, sometimes it's hard to find a fastener spot around the fenders.
    Now the deck over. Pro's More surface space on the deck, No fenders to avoid, Can have fastners all along the rails.
    Con's Heavier, Higher center of gravity while driving, harder to load because of heights
  7. #7
    New Member
    Join Date
    Jul 2012
    Posts
    23
    Austin texas
    Bobcat S650
    I wouldnt buy anything until you talk to Tiger Trailers. These are the most overbuilt trailers I have seen, and thousands less than Big Tex for what you get. My flatbed will haul anything that will fit on it. Its literally a 20K deck on 14K axles and it has two 6K gooseneck jacks on the nose. Trout trailer Sales in Porter Texas is where I got mine. They have prices on their website.
  8. #8
    Join Date
    Sep 2012
    Posts
    78
    Weatherford, TX
    '69 MF 135
    Ii believe I have a tiger dealer in town here. How heavy is that beast? Currently only have a 1500 dodge to pull with.
  9. #9
    Join Date
    Sep 2000
    Posts
    6,259
    Eastern NY
    That's probably a 2500-3000lb tare wt. trailer. Overkill for a half ton pickemup.
  10. #10
    New Member
    Join Date
    Jul 2012
    Posts
    23
    Austin texas
    Bobcat S650
    I believe its in the 3000 to 3500 pound range. That being said, its the best pulling trailer I have ever pulled. I dont feel it back there at all.
Similar Threads
  1. 16 or 18 ft car hauler?
    By Isaac1 in forum Trailers & Transportation
    Last Post: 04-23-2012, 09:53 AM
  2. Building a flatbed for a regular pickup?
    By IHDiesel73L in forum Projects
    Last Post: 07-20-2011, 04:49 AM
  3. Delta Car Hauler
    By yooperdave in forum Trailers & Transportation
    Last Post: 12-13-2009, 09:07 PM
  4. 8,000# x 18' Car Hauler
    Last Post: 07-27-2009, 11:07 PM
  5. Anyone use a car hauler for their tractor?
    By BobinIL in forum Attachments
    Last Post: 09-07-2006, 03:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
