Results 1 to 7 of 7
  1. #1
    Join Date
    Jul 2012
    Posts
    51
    Eastern,PA
    Kubota GL3540
    Default Chaining a kubota
    Is there any special way to chain the front end of a Kubota 4wd 3540 down? A buddy of mine told me that kubota has a certain way it's supposed to be done over the front axle.
    Thanks for your help
  2. #2
    Join Date
    Apr 2011
    Posts
    586
    Boston
    L3700SU
    Default Re: Chaining a kubota
    I like to run a strap through the big tube between the loader arms. That is about the best point I have found to tie to.
  3. #3
    Super Member
    Join Date
    Apr 2000
    Posts
    7,593
    Shingle Springs California
    New Holland TC40D
    Usually if it has specific requirements, it would be in the manual. What does the dealer say?
    RobertN in Shingle Springs Calif
  4. #4
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I like the chain attachment bar that is on my B26 under the front and on the backhoe. Just run my chain thru it and bind it down. I then put a strap across the FEL arms as they have no sharp edges and strap across the dipper on the back hoe just as extra precaution. I use straps rated at WL 5200# and the chains are 3/8" grade 70.
    As for chaining over the front end, I would think as long as you arent on top of the tie rods or your chain is not on the oil plugs on top of the axle that you would be good to go. Just look where your chains are riding to make sure they arent on top of something that will bend or break.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  5. #5
    Elite Member schmism's Avatar
    Join Date
    Jul 2006
    Posts
    4,662
    62014 IL (outside STL MO)
    New holland TC(33)
    My TC33 has a front frame extenion that acts as a weight rack/small bumper, I loop the chain through that on mine. If you have a front weight rack/bumper/grill guard i would suggest the same. If not and you just have the nekid front end, then i would wrap around the axle. You could use axle straps and chain to those also.
    Steve - TC33D 4x4 FEL, dual rear remotes with toys
  6. #6
    Silver Member beckmurph's Avatar
    Join Date
    Jul 2005
    Posts
    192
    Home/Catlettsburg Farm/Robinson Creek, Ky
    Kubota B3200TLB BX25(sold) b2620TLB(sold)
    I run a strap over the bucket on the fel. Then I run a chain through the frame of the B3200 just behind the grill guard. Then I run a strap through the lower portion of the backhoe. Then I run a chain across the backhoe bucket resting on the deck of the trailer.
    If I have the bush hog on the tractor, I run a strap across the lower links on the tph, and a chain across the back of the bush hog.
    2012 B3200TLB Woods RB72 Rear Blade Woods RFM60 Finish Mower Woods RCR48 Rotary Cutter
  7. #7
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    Quote Originally Posted by Tomtint View Post
    That's also what I like to do.
Similar Threads
  1. Chaining it down ?
    By pdqford in forum John Deere Owning/Operating
    Last Post: 05-19-2012, 11:38 PM
  2. chaining down your equipment
    By newengland mower in forum Safety
    Last Post: 10-01-2011, 11:53 AM
  3. Chaining down attachments
    By AlanB in forum Safety
    Last Post: 10-05-2007, 05:53 AM
  4. I need help chaining down the tractor
    By RPK in forum Trailers & Transportation
    Last Post: 07-24-2007, 11:32 AM
  5. Chaining down equipment
    Last Post: 08-05-2006, 03:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
