Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
  1. #21
    Elite Member Car Doc's Avatar
    Join Date
    Mar 2009
    Posts
    2,972
    Kansas
    YM3810D Yanmar
    Default Re: truck battery dead after parking with trailer hooked up
    Quote Originally Posted by joshuabardwell View Post
    I hate having to un-do the U-bolts and take apart the weatherproof box to get the battery out. Also, I hate the idea that if I stored the battery indoors on a charger, I would have to take the time to put it all back together before using the trailer. So I put one of these ring terminal harnesses on it.
    Attachment 291835
    That way, I can easily put a trickle charger on the battery every once in a while to keep it topped off. My breakaway kit is not wired with a charger circuit, so I can't charge it through the vehicle harness.
    Yeah those are great a real time saver! OReillys has the 2 wire flat ends as a pair for a few bucks. I have them on my Harley and all my mowers and cars that sit awhile. Plus I took all my HF float chargers and put the 2 wire flat ends on them makes it easier to hook anything up to any one of my maintainers.
    Yanmar YM3810D, LT duty 3pt hoe, 6' KK2 tiller, 6' KK box blade, 6 1/2' KK disc, 5' Howse bush hog, 5' Howse back blade, 9" Yellow PHD, 3 Husky chain saws 346XP NE, 359, 372XP. 07 HD Heritage Softail, Crack injectors, check compression, take 2 beers and call me. "Hey you didn't build that."
  2. #22
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default
    Quote Originally Posted by jwstewar View Post
    Like I said before, I actually prefer it this way. I think GM did it the correct way. It also allows you to use the plug for other things back there. I have my diesel fuel pump rigged up to run off it. I can fill my tractor by plugging into the trailer pig tail. I also have a small water pump rigged up this way so that I can transfer water from the storage tank on the truck to the holding tank of the camper. I also have my yard sprayer rigged up to use the same plug. So, again I'm quite glad that GM did it this way. I would be mad if I had another brand and couldn't use it the way I want and probably would be rewiring it.
    All you would have to do is turn on the key. GM did it wrong, plain and simple. There is a reason Ford, Nissan, Toyota, and Dodge did it the other way.
    Chris
  3. #23
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by Diamondpilot View Post
    Chris
    I have to agree with DP on this. When I turn off the key, I expect the power to everything except lighting and emergency flashers to be off.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  4. #24
    Join Date
    May 2012
    Posts
    2,231
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by Gary Fowler View Post
    That was my thought. If I want accessory power, I generally only want it to be on when the key is in the on or ACC position. Any alternative is just an invitation to run down one's battery. I will say that I have seen a few cars where they have one 12-volt receptacle that is keyed and one that is always on--perhaps if you are going to have some accessory that you want to charge up even when the car is off. I thought that was an okay idea, I guess.
  5. #25
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Default
    My Nissan Titan not only came factory with a sprayed in bed liner but also a water tight 12v receptacle in the bed. Only time I have used it in 6 years was once to plug in a 12v air compressor and many times tailgating to plug in a inverter for the TV and blender. My buddy with a Titan uses his every day to plug in his battery chargers for his cordless tools while on the construction site.
    Chris
  6. #26
    Join Date
    Mar 2009
    Posts
    2,972
    Kansas
    YM3810D Yanmar
    I drive Toyota's and have for years and learned to live with the key switched lighter sockets. It has caused me a few times to want to wire one thats hot then I say nah and I forget about it.
  7. #27
    Veteran Member jwstewar's Avatar
    Join Date
    Sep 2001
    Posts
    2,225
    South Central Ohio
    2003 New Holland TC24D
    Default
    To each his own, I'm just glad my GM's are done correctly - for my purposes. Just another reason for me to not like Ford.
    Jim
    New Holland TC24D
  8. #28
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    I suppose each company has a reason for wiring the way they do as it seems a split here on how folks like them. I still need to find out why my battery went dead. Didnt get to it yesterday to check the battery on the trailer as weather is kind of crappy with light mist.
    It looks like it will take a bit of work removing battery cables to measure the current draw to the trailer and I have company coming in from Houston today so might be a few days before I get to it.
  9. #29
    Join Date
    Jan 2007
    Posts
    12,446
    Daleville, IN
    Default
    Again, GM does it one way and everyone else does it the proper way for a reason. This thread is a case in point. It might work for you but its caused issues just like this for years in as little time as one may be just at a hotel for the night. Another is a camper left hooked to the tow vehicle for a quick overnight followed by a truck that will not start because the camper backfeed of the truck. I have seen it a dozen times in my business.
    If you need power at the rear run a dedicated circuit.
    Chris
  10. #30
    Gold Member
    Join Date
    Jan 2011
    Posts
    275
    Richmond, IN
    Kubota MX5100
    Default
    I thought those circuits went dead after 10 minutes or so on GM vehicles? I've always liked having accessory sockets that are hot with the key off. That's a plus!
    Kubota MX5100
    '95 Ram 2500 CTD
    Stihl MS441 ported
    Stihl MS280 ported
Similar Threads
  1. Hooked battery up backwards JD LT 133
    By tjburris in forum Parts/Repairs
    Last Post: 03-26-2012, 10:37 PM
  2. Dump Trailer - How many dumps before battery is dead?
    By 1greenmachine1 in forum Trailers & Transportation
    Last Post: 05-23-2011, 09:12 AM
  3. Z4822 Battery Hooked up backwards
    By robdog6942 in forum Husqvarna
    Last Post: 04-29-2010, 08:24 PM
  4. Battery hooked up backwards,OOP!
    By sola mesa in forum Owning/Operating
    Last Post: 12-20-2009, 11:03 PM
  5. Battery went dead in truck
    By Scott_in_WVA in forum Related Topics
    Last Post: 08-12-2002, 03:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
