Results 1 to 10 of 20
12-09-2012, 09:08 PM #1Silver Member
- Join Date
- Sep 2012
- Posts
- 104
- Location
- South of Mason Dixon
- Tractor
- Massey Ferguson 2615L
Trailer shopping help needed
I am looking to purchase in the near future a new trailer for hauling my tractor and various attachments.
I am thinking bumper pull 14k tandem axle 24' x 7' low boy with slide in ramps possibly a steel deck. reccomendations and advise appreciated.
My tractor is 18 feet from front of fel bucket or grapple to the rear of my 7' box blade add 6 feet to that for rotary cutter. With loaded tires I am from 6200 to 7400lbs dependending on attachments.
12-09-2012, 09:17 PM #2Veteran Member
- Join Date
- May 2012
- Posts
- 2,260
- Location
- Knoxville, TN
- Tractor
- Bobcat CT225
Re: Trailer shopping help needed
My only comment is, if you're going to tow 14k bumper pull, make sure that your tow vehicle's hitch is up to it. Most factory hitches require a weight-distribution system to get up that high, if they can do it at all. You can get class V hitches rated for 14-18k without a WD system, but they are almost, if not always, aftermarket. Frankly, towing that heavy, a WD system might not be a bad idea even if your hitch doesn't technically require it.
12-09-2012, 09:37 PM #3Platinum Member
- Join Date
- Apr 2012
- Posts
- 642
- Location
- pa
- Tractor
- kubota 7040sud
buy a trailer like a cam superline maxum etc cheap trailer will not hold up i have a 10k 20 foot maxum i pull my 7040sud fel loaded rear tires cast centers it weights 8000+ ibs i hual skid steers ect no problems
12-09-2012, 09:56 PM #4Elite Member
- Join Date
- Jan 2009
- Posts
- 3,564
- Location
- Preble County, Ohio
- Tractor
- Kubota B7800 with FEL
I have owned two of these. Both were 10K bumper pull. First one was a 16' and the second was an 18'. I really liked these trailers.
Hudson Brothers Trailer Manufacturers, Inc, Indian Trail, NC........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
jerry clowers-a coon huntin story.
12-09-2012, 09:57 PM #5Silver Member
- Join Date
- Sep 2012
- Posts
- 104
- Location
- Tractor
yes WD for sure tow vehicle is 2011 f250.
12-10-2012, 08:21 AM #6Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,480
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
My only comment is to go with a wood deck. With mud or just a little bit of moisture them steel decks are slicker than snot.
Chris
12-10-2012, 08:50 AM #7Silver Member
- Join Date
- Mar 2012
- Posts
- 116
- Location
- Outthere, WA
- Tractor
- Kubota 25D
Just curious why BP?
I've done BP horse trailers growing up in the 18' range, a few years ago I got a 28' enclosed BP and I'll never do that again. Hoping to trade up to a 5th wheel because at max capacity that bumper pull was not fun to pull down the highway...
12-10-2012, 06:53 PM #8Platinum Member
- Join Date
- Oct 2009
- Posts
- 667
- Location
- IL
- Tractor
- Ford 555 TLB, Xtra-Vator, pallet forks; Caterpillar 12 Motor Grader; FABTEK aerial platform
24' is about the longest I'd want to go on a tag trailer. I agree that a wood deck would be better.
I don't know if they have what you're looking for but Behnke trailers are built like a brick ****house.
12-10-2012, 10:19 PM #9Gold Member
- Join Date
- Dec 2010
- Posts
- 296
- Location
- Central Texas
- Tractor
- Kubota L235
Unless you have a very specific need to go with a Bumper Pull, I'd suggest you consider a gooseneck for that size and weight. Your equipment comes in around 7000#, the trailer is probably around 5000#, so 12000# Bumper Pull is really pushing it. I run a BP of just under 10,000# and I feel that is really pushing the limits - 2012 F250 diesel. And I agree with the comments about a wood deck.
Kubota L235
John Deere 5055E
12-10-2012, 10:48 PM #10Elite Member
- Join Date
- Jul 2006
- Posts
- 4,662
- Location
- 62014 IL (outside STL MO)
- Tractor
- New holland TC(33)
big tex 22' 14K lb tilt is 3500lbs http://bigtextrailers.com/pdf/14tl.pdf Add 2' and ramps and you'd be at or under 4000lbs curb weight. with a 10% tounge weight, that puts your net (cargo) weight at 11,400lbs. (personally id just go with the 22' above and fudge the last 2' off the back)
but only if you have a class 5 receiver and a WD hitch. (FYI they go all the way up to 17,000 1700TW on a 2.5" hitch if need be Reese Titan Weight Distribution w/out Shank - Trunnion Bar - 17,000 lbs GTW, 1,700 lbs TW Reese Weight Distribution RP66006)Steve - TC33D 4x4 FEL, dual rear remotes with toys
Similar Threads
Trailer Shopping!
By Martian in forum Trailers & TransportationReplies: 7Last Post: 04-04-2012, 08:43 PM -
Scout Troop Shopping for Covered Trailer
By 702mule in forum Trailers & TransportationReplies: 9Last Post: 06-27-2011, 09:47 AM -
Grapple HD grapple shopping advice needed
By ManAtArms in forum AttachmentsReplies: 26Last Post: 01-15-2010, 08:19 AM -
trailer shopping
By schmism in forum Trailers & TransportationReplies: 5Last Post: 07-26-2008, 02:13 AM -
It's GO TIME for my trailer shopping!!!
By GreatWhitehunter in forum Trailers & TransportationReplies: 42Last Post: 06-08-2008, 08:59 AM
