Results 11 to 20 of 39
01-28-2013, 08:19 PM #11
01-28-2013, 09:50 PM #12Bronze Member
- Join Date
- Nov 2012
- Posts
- 71
- Location
- ramah, co
- Tractor
- none yet
Re: absolutely pointless rant
i got the end of the tap out of the hole by vigorously beating on a punch with the biggest hammer i could swing in the fender well. the end of the tap is in the frame but it won't hurt anything in there. i had the tap centered when i started cutting the threads but it moved off the center line. i didn't catch this until the threads were pretty well started. when i tried to adjust it, the tap broke. such threads as i had would do me absolutely no good at all as i would not be able to get the bolt started due to the improper angle (like i said, i botched it).
i can't have a nut welded inside the frame as the frame is boxed. a stud is a possibility though. i'll ask when the welder shows up.
01-28-2013, 09:54 PM #13Super Member
- Join Date
- Nov 2011
- Posts
- 6,385
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
Good luck.
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
01-29-2013, 12:26 AM #14Veteran Member
- Join Date
- Mar 2009
- Posts
- 1,023
- Location
- Lee, IL
- Tractor
- John Deere 1070
01-29-2013, 01:44 AM #15Bronze Member
- Join Date
- Nov 2012
- Posts
- 71
- Location
- ramah, co
- Tractor
- none yet
there are two holes in the frame where the upper a-arm is bolted. the area immediately adjacent to the two holes is proud of the rest of the boxed frame rail. i'm not sure exactly what this is for as it was not machined in any way to ensure that the two holes are co-planar. if the welder were to cut that immediate section out he would have to build that area up and then we'd have to figure out some way to spot face that hole to be co-planar with the other.
i had thought of have that general area cut out and replaced, but there is a shock tower welded right there and the whole thing is rather complicated. if the welder and i agree that he can provide and safe and effective repair then that's what we'll do. if he can't, i'll buy another 95 pathfinder, move any better parts that i have over, and scrap this vehicle. i've been screwing around with this for two months and i'm sick of looking at it up on jackstands. tomorrow, if the welder shows up, will tell the tale.
01-29-2013, 02:32 AM #16Super Member
- Join Date
- Aug 2006
- Posts
- 5,103
- Location
- Front Range of Colorado
- Tractor
- JD 4200 C.U.T. & JD 130L Lawn tractor
Dhagood...keep McMaster-Carr McMaster-Carr in mind when you need unique fasteners. I've found stuff there that I didn't know existed.
My 24/7/365 menu for GITMO: Bacon for breakfast, a ham sandwich for lunch, and a pork chop for dinner.
Stuff I've made for the JD4200 or done with it are at this link. http://picasaweb.google.com/mjncad
01-29-2013, 06:17 PM #17Bronze Member
- Join Date
- Nov 2012
- Posts
- 71
- Location
- ramah, co
- Tractor
- none yet
01-30-2013, 03:46 PM #18Platinum Member
- Join Date
- May 2005
- Posts
- 942
- Location
- Eastern MA & Upstate NY
- Tractor
- John Deere 770, Bobcat 753
Tricky location, but I think it can be repaired. The welder would need to cut out the hole and replace with a nut welded to a small patch plate. The plate could then be welded in from the outside, flush for proper fit.
“I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
01-30-2013, 07:37 PM #19Bronze Member
- Join Date
- Nov 2012
- Posts
- 71
- Location
- ramah, co
- Tractor
- none yet
the welder showed up today, he looked things over, and we agreed that the most economical repair that had a chance of succeeding was to build up material in the stripped out hole via TIG welding, redrill the hole, and tap new threads. to do anything different would run into some sort of fabrication expedition of unknown length and cost. could the vehicle be completely repaired? sure, you can repair anything with enough time and budget. time is not an issue, but budget sure is. not only do i not want to spend much money, but the vehicle according to kelly's blue book is worth around $600 to $750. it's just not worth much expense.
so he welded, we drilled, and we tapped. i paid him $50, and he left. i bolted the a-arm up, applied torque, and shook my head as the threads stripped out. and thus does a vehicle die.Last edited by dhagood; 01-30-2013 at 08:29 PM.
01-30-2013, 08:35 PM #20Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,446
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Well you gave it a good shot.
Chris
Similar Threads
Is a filter absolutely necessary for hydraulics?
By chad22 in forum HydraulicsReplies: 34Last Post: 04-08-2011, 12:20 AM -
The thread about absolutely nothing...
By Podunkadunk in forum Related TopicsReplies: 59Last Post: 04-19-2009, 09:42 AM -
By Podunkadunk in forum Buying/Pricing/ComparisonsReplies: 4Last Post: 01-18-2007, 03:07 PM -
I am absolutely stuck!! TC24D or TC 29D??
By horstuff in forum New Holland Buying/PricingReplies: 18Last Post: 06-22-2004, 10:25 PM
