Results 31 to 40 of 52
01-19-2013, 09:41 PM #31Silver Member
- Join Date
- Nov 2011
- Posts
- 198
- Location
- Canton, TX
- Tractor
- JD 301A and yanmar YM2500
The truck is a 95.5 PSD. They did make a bunch of changes between 94.5my and the 1996my but started calling it a power stroke for the 95my. A lot of the parts for the 7.3 are the same between 95 and 2000 and even after.
01-19-2013 09:41 PM # ADS
01-19-2013, 09:49 PM #32
01-19-2013, 09:57 PM #33
Re: Bought a heavier duty truck today at a yard sale
Yeah I agree, you stole it. In my area, the 7.3 psd is sought after. An great deal in my area would have been twice what you paid, and i've seen them for 3 or 4times what you paid. I'd spend the money and get the rust fixed. It would be a battle, but I think it would be worth it.
Dave,
BX2350
01-19-2013, 10:11 PM #34Veteran Member
- Join Date
- May 2005
- Posts
- 1,022
- Location
- Balls Creek, NC
- Tractor
- New Holland 1720
Those 7.3's will run a long time...
That truck will bring 10K all day up here in North Carolina...
Yes, you stole it...
I would check the SCA's and perhaps flush the radiator...
I flushed my 03 5 years ago and it is time to do it again...
You got a great deal...
01-20-2013, 07:56 AM #35Gold Member
- Join Date
- Oct 2010
- Posts
- 350
- Location
- Lecanto Florida
- Tractor
- Kubota L2900
My son and I took the bed off last night. We cut the heads off of the bolts that hold it on, took out the tail lights, filler neck, and aux fuel tank.
After we had everything disconnected my other two sons helped us roll it off the frame onto the ground. It was easier than I thought.
The good news is that the rust damage was about what I suspected. It is mostly scale that comes off of the frame easily. The spare tire lifting mechanism is shot but that is no big deal. It also has new brake lines on the rear end. He told me that he had all new brakes put on it before he put it up for sale.
Looking under the truck the rust from the front to the rear is much different. At about the rear of the cab you can still see the color of the frame and the farther forward you go, the less rust there is.
Both rear bottom corners of the bed have rust damage that I will get fixed before I put a new bed on it.
Mechanically I think he took pretty good care of the truck. He told me he changed the oil every 5k. He gave me part of a galln of of shell oil and said that was all that had ever been in it. He also gave me two bottle of diesel additive and told me he always put it in when he filled it up.
He also told me when he had the transmission fluid changed but I don't remember what he said. I think I will go back and ask him about the transmission and when, if ever he had the radiator flushed. If he hasn't I will flush it and follow the above recommendations.
My son says I should have the muffler taken out and just run straight exhaust like he has on his truck. Would I gain anything if I do that? Thanks again for all of the help
01-20-2013, 08:16 AM #36
Good deal!
Now that the bed's off it's a good time to check the gas tank straps (prone to rot and break), change the rear diff fluid (easy access), the rear shocks and mounts (might as well replace the shocks), the leaf spring shackles (prone to rot and cracking), and exhaust. A straight pipe vs the muffler won't add a ton of power or even be very noticeable unless you replace the entire turbo back exhaust with a larger 3". Here in NH the turbo counts as a muffler so you don't need a muffler for state inspection. Your state may allow that as well.Derek
Kioti CK20HST
KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
Sims-Cab Depot heated cab
Originally Posted by DiamondPilot
01-20-2013, 08:22 AM #37
At 140,000miles my 99 f350(6speed)7.3stroke gave out. The injection cups went out allowing antifreeze to get into my fuel system and $3500 later,its still not done...I called mechanic and told him I was done with the ford that I will come get it and take to salvage yard.
You got a very good deal on your pickup
01-20-2013, 08:44 AM #38Gold Member
- Join Date
- Oct 2010
- Posts
- 350
- Location
- Lecanto Florida
- Tractor
- Kubota L2900
Thanks Dmace. I don't think I am worried about adding power, although I would take it. I would be more interested in adding fuel economy. I don't think I will be driving this enough to justify spending a lot on the exhaust. There is a good muffler shop near me. I will stop by one day and get some prices.
Like you said about the other items now is a good time to look at the exhaust while the bed is off. I am going to meet my wife at the tag agency tomorrow and put plates on it so I can start driving it around as I work on it.
01-20-2013, 08:53 AM #39
If you're going to do a flush, take a look at the link I posted earlier and do a flush of everything. It's a nice step by step and also flushes the block.
As far as the exhaust, I don't know. How loud do you want it to be? My 7.3 is 3 model years behind you, so I don't know if all my mods would apply to you, perhaps Soundguy could contribute there. Not sure about your downpipe from the turbo, but for a few years they were squished almost flat. Guys called them a cobra head. A lot of us have replaced those with 3 or 4 inch wide open downpipes and then replaced the factory intake with what many call a Tymar type. Personally, I bought a K&N kit. But after a little research I decided to keep the K&N hardware and replace their filter element with a Donaldson paper filter. But I would say that the downpipe and intake are among the most common mods that people make to start out with.
Probably the best thing to do is to tow what you're normally going to tow with it in it's current configuration. Then decide from there if you need more power or performance from it before you start throwing money at mods you may not need.Todd
_____________________________________________
"The trouble with quotes on the Internet is that it's difficult to discern whether or not they are genuine." --Abraham Lincoln
2008 Bobcat S185 Skid Steer with enclosure, heat & A/C • Erskine model 2010 73" blower •TSC Boom Pole adapted to QA • Bradco 48" pallet forks • JLG T350 Boom Lift • 1997 Ford F Super Duty 7.3 Powerstroke w/ Altec AT 200A aerial lift • CAM Superline 6x12 dump trailer
01-20-2013, 09:22 AM #40Gold Member
- Join Date
- Oct 2010
- Posts
- 350
- Location
- Lecanto Florida
- Tractor
- Kubota L2900
JJZ 109, I will definately follow the link you posted for the flush. Even if I don't flush it right now I am going to save the information in my truck file for later.
Exhaust info is intersting, I will look into it. First thing is to make sure everything else is in good working order.
Similar Threads
heavier duty pallet forks?
By hrcarver in forum AttachmentsReplies: 6Last Post: 05-27-2011, 09:50 PM -
Can I Beef Up My Truck for Heavier Payload?
By Haoleguy in forum Trailers & TransportationReplies: 55Last Post: 05-16-2011, 07:09 AM -
heavier duty Kubota front end question?
By Piston in forum Buying/Pricing/ComparisonsReplies: 4Last Post: 04-10-2011, 09:56 AM -
GN--pick up to med. duty truck
By MIspecial@mac.com in forum Trailers & TransportationReplies: 10Last Post: 03-30-2008, 08:28 PM -
Medium duty dump truck
By Rowski in forum Related TopicsReplies: 19Last Post: 06-28-2005, 08:29 AM
