Results 51 to 52 of 52
01-22-2013, 09:35 PM #51Silver Member
- Join Date
- Sep 2006
- Posts
- 136
- Location
- ohio
- Tractor
- kabota
Re: Bought a heavier duty truck today at a yard sale
THE PICKUP ASSEMBLY HAS A ROUND SCREEN ON THE BOTTOM THAT CAN FALL OFF INTO THE TANK.THERE IS ALSO 2 MESH NYLON SCREENS THAT NEED CLEANING THAT YOU CANNOT SEE IN SIDE OF THE ROUND PLASTIC CYLINDER THAT IS SNAP LOCKED TOGHETHER.YOU CAN BUY A KIT TO DO AWAY WITH THIS AND ADD A EXTERNAL FILTER BEFORE THE PUMP LOCATED INSIDE THE FRAME. PS YOU WILL NEED TO BUY A REMOVAL TOOL FOR THE FUEL LINES.
01-28-2013, 10:28 PM #52
What $3200 for that!! That's a $7000 truck all day long here maybe more!! And diesel!! Spend $500 and you can have a good back yard guy fix that where you don't know its there!!, then just coat the underside after getting rid of rust. WOW im still blownaway!!
YM2000. MF dirt scoop,4' Jbar bushhog,boompole, LMC 12-16 disk harrow, 4' Atlas boxblade (with rippers). 1980 chevy K10,1990 ford ranger 2wd (285K miles),1997 saturn SL2 (twin cam!!),2001Toyota Higlander
1986 Cobia 177 sunskiff w/1981 Johnson 60 hp
1991 Javalen 17ft w/same year 150 Johnson GT
Troybuilt 4 cycle & Echo 2 stroke,cold natured(need carb rebuild),MS390 Stihl, Northern tool pressure washer, mixes water into the oil in the pump(now dead, motor on a tiller). 5000 watt generator.
Similar Threads
heavier duty pallet forks?
By hrcarver in forum AttachmentsReplies: 6Last Post: 05-27-2011, 09:50 PM -
Can I Beef Up My Truck for Heavier Payload?
By Haoleguy in forum Trailers & TransportationReplies: 55Last Post: 05-16-2011, 07:09 AM -
heavier duty Kubota front end question?
By Piston in forum Buying/Pricing/ComparisonsReplies: 4Last Post: 04-10-2011, 09:56 AM -
GN--pick up to med. duty truck
By MIspecial@mac.com in forum Trailers & TransportationReplies: 10Last Post: 03-30-2008, 08:28 PM -
Medium duty dump truck
By Rowski in forum Related TopicsReplies: 19Last Post: 06-28-2005, 08:29 AM
